coolant going into exhaust
I did a timing belt, tensioners and water pump on a 94 3.0 and now i have coolant coming out the exhaust. Could there be something with the tensioners causing that?? Ran fine didn't loose any coolant until changing those parts. I don't see how it could be related but thought I would ask.
Hi I am very new here. But since no one else has answered yet I thought I'd give it a go. The only way coolant could be coming out your exhaust is if you have a leak from a water jacket into the cylinder via damaged gasket or seeping from the head into the cylinder. I don't think the items you changed could be the problem unless you damaged the head gasket during install? I doubt that would be the case. Can you think of anything else that might be the problem? Running to hot, etc?
