Coolant in Exhaust
Old 05-08-2010, 06:51 PM
TCLade's Avatar
Coolant in Exhaust
I am a recent member (not so recent owner) and have a tricky problem I can't diagnose.
I have a '86 PU 22R - 4cyl - carb - stock - 170k - daily driver.
I had a recent 'head gasket failure' that resulted in a steam funnel from the tailpipe. Got hot but never pegged the gauge.
Replaced head gasket and torqued everything down - still constant coolant exhaust.
Brand new head from Engnbldr - Street RV and torkrCam!
Cleaned EVERYTHING - still steam!!!!!!!!
It has new many things - inc. timing chain & cover plus all the usual items - plugs etc.
Ideas????!
Old 05-08-2010, 07:08 PM
pruney81's Avatar
You didn't put everything back together properly?
Old 05-08-2010, 07:35 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
head warped....
I'd never put a head back on any engine that didn't go to the machine shop 1st...
Or you can buy the hyper accurate "machinists straightedge" for a $100 or 2...
Old 05-08-2010, 07:55 PM
pruney81's Avatar
he said it has a brand new engnbldr head so that would rule out warpage
Old 05-08-2010, 08:07 PM
TCLade's Avatar
Yup, it's all new. I even took a short test drive, pulls like a champ (thanks Ted).
I'm pretty confident that all went back together correctly. The problem was the same after replaced the gasket before I pulled it ALL off again to wait for a new head.
Still baffled. Thinking intake manifold....
Old 05-08-2010, 08:49 PM
yayfortrees's Avatar
PM sent
Old 05-09-2010, 06:49 AM
swampfox's Avatar
it might be burning off coolant that collected in the muffler. i replaced a motor in a truck that had blowed the head gasket ,when i started it up it poured water and steam like crazy out the tail pipe until it dried out.
Old 05-09-2010, 07:39 AM
TCLade's Avatar
How long did it take to dry??
Old 05-09-2010, 07:47 AM
Blue_petersen77's Avatar
I wouldn't think it would take very long to burn of residual coolant in the exhaust sytem maybe one day of long travel or 2. But then again coolant is made to withstand high temps...
Maybe pull it on to the steepest incline you can find and let it run for a bit so gravity can help pull out any extra fluid.
Old 05-09-2010, 07:50 AM
TCLade's Avatar
I'm going out right now to drop the exhaust and see if it drains - I'm that obsessed!!! Thanks for the advice..
Old 05-09-2010, 07:55 AM
That sounds like too much wrenching for me lol. Like I said, I'd park it on the steepest place I could find... Or maybe I'm just lazy =)
hope you get it drained out and that's all it is man.
Old 05-09-2010, 08:25 AM
swampfox's Avatar
the truck i done had been ran hot filled with water and over heated again .it had alot of water in the muffler.it ran a large puddle on the floor. i think it took around a hour after it hit operating temp.but that was idling only not being drove.
Old 05-09-2010, 09:30 AM
DoveGray85's Avatar
I'm interested in hearing about what you found out. I'm also having head gasket issues with my 22re.
Is the coolant level in the radiator actually going down? Or are you just seeing some white smoke out the exhaust? I would re-torque the head bolts for one thing, just to make sure.
Old 05-09-2010, 09:31 AM
TCLade's Avatar
Talking
Well boys, you did it. I pulled the exhaust, no water. Pulled the plugs, no coolant spitting. I idled the thing for 1/2 hur, solid temps and steam CLEARED!!!!!
Just got back from test drive and everything seems great. Going to reset the valves and call it good (oh and join AAA finally!)
You guys ROCK; thanks to SWAMPFOX and BLUE PETERSON77
Old 05-09-2010, 09:56 AM
Glad it was something simple for ya man. I got 206755 on the clock and already dreading the whole head gasket scene!... Eh, maybe I can get to 300000 before it goes (crosses fingers and toes)
Blamalam
03-12-2022 07:34 AM
Tennesseestorm
09-12-2015 01:37 AM
idadan208
09-07-2015 09:06 AM
Corvoid
09-04-2015 11:55 AM
izzmee
08-17-2015 10:20 AM
Quick Reply: Coolant in Exhaust
