coolant everywhere, help please.
Old 07-02-2008, 04:01 PM
skinnyhb's Avatar
i just did my battery intake swap and adjusted my timing. upon startup, everything ran great until i turned off the truck and noticed coolant leaking everywhere. all of my hoses are good and it looks like it is coming from somewhere in the radiator. i took off the fan shroud to put the engine at top dead center and initially i thought that i might have put one of the bolts too deep and punctured the radiator, but it appears that isn't the case. does anyone have any ideas? did my radiator blow up or what?
Old 07-02-2008, 04:05 PM
Jay351's Avatar
Hehe, no idea. Just follow the drip drip drip.....
Old 07-02-2008, 04:40 PM
Snotrocket's Avatar
LOL yeah thats all you can do.
Pray it's not the headgasket......
Old 07-02-2008, 05:23 PM
scuba's Avatar
could be the water pump/ and or gasket.
i just replaced both in the process when i was losing coolant.
still losing coolant tho , and oil...bad block
Old 07-02-2008, 05:31 PM
Jay351's Avatar
Damn, thats gotta suck!
Old 07-02-2008, 05:33 PM
4Crawler's Avatar
You could get a cooling system pressure tester and pump up the pressure in the system to force coolant to leak out and it'll be easier to find with the engine off.
Old 07-02-2008, 05:42 PM
skinnyhb's Avatar
well, the coolant was definately coming from the radiator area. i drained it an pulled it out, and it isn't milky from waht i can tell. i filled it back up and drove around the block for 20 minutes or so. now it is not leaking at all and i'm just plain confused. is is possible that i overfilled it previously?
Old 07-02-2008, 09:18 PM
just a 22re's Avatar
you may have gotten water on the fan and plastic thingy around the fan and when you atarted it it just sprayied it everywhere?
Old 07-02-2008, 09:24 PM
ozziesironmanoffroad's Avatar
question, did you fill up the backup coolant tank (sorry i cant spell resoiver) to the top? if so, thats prob your problem lol
Old 07-02-2008, 09:26 PM
CJM
CJM's Avatar
x2, its not an expensive tool and highly worth it.
Old 07-03-2008, 02:17 AM
skinnyhb's Avatar
no
"question, did you fill up the backup coolant tank (sorry i cant spell resoiver) to the top? if so, thats prob your problem lol"
no
"x2, its not an expensive tool and highly worth it."
interesting
i wonder if a combination of a very full radiator and some air in the cooling system just caused a failure at pressure for the radiator, because i refilled it and attempted to get the air out and it hasn't happened since.
JonG85
01-18-2023 04:31 PM
ladybugRC
458
08-21-2020 10:41 AM
alexcarey
10-14-2015 06:05 PM
kcaudill
10-10-2015 02:39 PM
tshort48
09-27-2015 01:04 PM
Quick Reply: coolant everywhere, help please.
