Converting EFI to a Carburetor - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-05-2006, 08:22 PM   #1 (permalink)
cweich's Avatar
Question Converting EFI to a Carburetor
Hello, i am new to site and was told maybe i could get some help from you guys. I am working on a 1987 yota pickup with a 22re engine. It currently is a 5 speed, however i am converting to a 1986 automatic. I am only using the running gear out of the truck, so please keep that in mind with my wiring questions. I would like to make this bare bones, i want to remove the efi and put a carb on it. What all has to be changed, Intake for sure, but will the head, distributor and coil work?
And then to complicate things i am adding the automatic trans to the equation, if i do away with the efi, i will remove the computer, but my auto trans has alot of wires coming from it, I am assuming being an 1986 its an overdrive, will the trans work with out a computer? I thank you guys in advance for the help with this project.
cweich is offline
Old 09-05-2006, 08:57 PM   #2 (permalink)
snap-on's Avatar
Send a message via AIM to snap-on
Quote:
AFAIK no.
the trans computer needs "lots" of imputs that im fairly shure are hosed if you dump the EFI system (ie TPS, speed sensor, and who knows what else)
Your in for a nighmare if you ask me.
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers
92 4runner, auto, V6, OME suspension, Downey headers
snap-on is offline
Old 09-06-2006, 05:32 AM   #3 (permalink)
Staff
Yoda's Avatar
You would need a dist & coil/ignitor from a carb engine. Try to find a manual trans. Prob cost you more to try to get an auto to work than to buy a stick.
__________________
David
TLCA 14788
71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap.
76 Landcruiser FJ-40 project/parts (haven't decided)
Yoda is offline
Old 09-06-2006, 05:33 AM   #4 (permalink)
Flash319's Avatar
I am not sure about the trans but you will need a carb intake and the carb distributor. Then you should be good. You may be able to buy a box that will run the trans but I don't know why you would want to auto anyway. It makes the 22re a dog...
Flash319 is offline
Old 09-06-2006, 06:12 AM   #5 (permalink)
AH64ID's Avatar
Send a message via MSN to AH64ID
Your going to make a gutless truck even more gutless....
__________________
-John
'05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600
2003 SR5 4Runner, V6 4WD. 1" cornfed lift
Previous Toyota's '92 Red Truck NALA
Speed doesn't kill, its the sudden stop that hurts.
AH64ID is offline
Old 09-06-2006, 08:55 AM   #6 (permalink)
cweich's Avatar
Auto Trans
Ok, so will the trans work at all with out the computer??? is there a different auto trans that could be recommended to me?? I want to stay automatic if i can.
cweich is offline
Old 09-06-2006, 08:57 AM   #7 (permalink)
cweich's Avatar
EFI Question
OK, so doing away with the EFI is fairly easy, but if i run the auto trans that requires the computer, what can i eliminate from the efi that does not really need to be there, this truck will be off road only, i want to simplify thing if this is possible. Thanks
cweich is offline
Old 09-06-2006, 10:03 AM   #8 (permalink)
04 Rocko Taco's Avatar
Send a message via AIM to 04 Rocko Taco Send a message via Yahoo to 04 Rocko Taco
Now that I got a lot more info from you, this sounds like a pretty cool ride... Keep me updated on the progress!!!
__________________
-Chris Tread Lightly!
04 Double Cab PreRunner. 3.4 - Auto
84 4Runner 4WD. 22R - 5 spd Lifted, Locked, 33x12.50
Disclaimer:My Photobucket is being revamped. If there are broken links, shoot me a PM. Thanks. ~Chris
Great Toyota Tech
04 Rocko Taco is offline
Old 09-06-2006, 10:04 AM   #9 (permalink)
anthony1's Avatar
Send a message via AIM to anthony1 Send a message via Yahoo to anthony1
Off road only? you want to keep your EFI....better at an incline. I've been with too many carb jeep/yota to tell you that it's not fun waiting for them to start up again at an incline.
__________________
http://www.angelfire.com/ca6/954runner
GOD's Country Best Seen In A 4 Runner. SAS front: lf,ARB,Ml4",Marlin arms, rear: cable elock,APlinks,OEmu860,35MT/R 5spd, 4:1.
..."But officer, that was not an illegal turn, it was just an undocumented turn."
anthony1 is offline
Old 09-06-2006, 10:11 AM   #10 (permalink)
snap-on's Avatar
-learn to drive a stick
-convert your 22r block to a 22re version.
while first gen EFI wasnt great i still belive its heads and tails better than a carb
my expertise is only on the 89 and above stuff so i dont have much to add for the auto behind a 22r. (if one existed)
__________________
snap-on is offline
Old 09-06-2006, 10:52 AM   #11 (permalink)
cweich's Avatar
I agree...I don;t think a auto existed with the 22r...i do know that 85 was the first year for the auto in the trucks
cweich is offline
Old 09-06-2006, 12:09 PM   #12 (permalink)
Flash319's Avatar
There is no such thing as "removing stuff that does not need to be there". The trans most likley needs the TPS, AFM, Temperature as well as maybe a pulse from the distributor to know what and when to shift.
It may work without any wires but I would assume that it won't.
just my 2cents
Flash319 is offline
Old 09-06-2006, 02:56 PM   #13 (permalink)
cweich's Avatar
just my 2cents
You're saying that i am fighting a loosing battle!! LOL...just my luck, thanks
cweich is offline
Old 09-06-2006, 03:22 PM   #14 (permalink)
Things to consider:
carb intake manifold
fuel pump
distributor
coil
ignitor
exhaust manifold (02 sensors)
radiator/tranny cooler
shift linkage
sender/vacuum plugs in manifold/head
and so on and so forth...
There is absolutely no reason to convert from EFI to carb on these trucks! You're better off buying a complete engine or even a different truck entirely.
curtiswyant is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
new carburetor XtraSlow_XtraCab 84-85 Trucks & 4Runners 6 06-22-2007 11:16 AM
EFI swap 22r truck to 88 4runner efi parts yotanothing 86-95 Trucks & 4Runners 2 02-26-2007 05:40 PM
carburetor adjustment sampson 95.5-2004 Tacomas & 96-2002 4Runners 2 05-30-2005 01:03 AM
Carburetor rebuild? the_supernerd 95.5-2004 Tacomas & 96-2002 4Runners 4 12-22-2004 11:25 PM
carburetor help please slider_buck 95.5-2004 Tacomas & 96-2002 4Runners 13 12-16-2004 05:31 AM
2009 InternetBrands, Inc.
