Converting built 22r to 22re
Hello there, the previous owner of my truck built up this 22r. I have most of the paperwork for it and I have read that cams that go in a carbed motor are different than an efi one. Is there anything else I should be aware of before I convert to fuel injection? Thanks
well there's a fuel pump in the gas tank not on the motor,
the entire motor electrical harness and computer, injectors ext.
2 fuel lines instead of one (I believe not positive)
that's all i can think of right now
Location: Downtown Heckronto, Ontario, Soviet Canuckistan
1 Post
If you want to keep the mods but get a little more usefulness (such as hill-climbing) out of your 22R, look into propane. It'd be a heck of a lot easier to do than finding and installing all of that EFI hullabaloo.
I daily drive this though. Would running propane have negative effects if being daily drove on?
1 Post
Lots of taxis seem to handle it just fine. You'd have to check local laws on whether or not you can do the conversion for an on-road vehicle. Overall fuel costs should be lower too, though I think propane costs more per gallon you use less of it.
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
