Control arm leak?
Old 10-25-2013, 05:17 PM
Daenerysdad's Avatar
Control arm leak?
So I was under my truck getting stuff prepped for my control arm swap, and I noticed a nice puddle of oil sitting just outboard of the shock mount. So just the passenge side shock and lower control arm are soaked in oil, nothing dripping from above, nothing else really saturated. Any thoughts? Blinker fluid blowing back from the bumper?
Attached Thumbnails Control arm leak?-d15627af-3878-4284-905b-5e7a4c319c65-1721-00000348b42e4c66_zpsa892b53c.jpg
Old 10-25-2013, 05:23 PM
250000_yota's Avatar
I'd suspect you've either blown that shock, or split a cv boot. Those are the only two things that could really leak down onto the control arm right there.
Old 10-25-2013, 05:26 PM
Well, I'll take either one of those. Replacing both tomorrow morning with a Bilsteins and t100 cv axles. But I'd suspect it's the shock, cause I checked the cv boot and it's fine.
Old 10-25-2013, 05:36 PM
arlindsay1992's Avatar
Do you have a Pickup or 4Runner? T100 axles will not fit. If the boot isn't torn and the CV's aren't damaged why would you replace the half axle?
Old 10-25-2013, 05:42 PM
I'm guessing since he mentioned the T100 axles specifically he's probably installing a long travel kit like a blazeland or total chaos.
'93 3vze pickup. Blazeland long travel getting swapped in, in a few hours. Just don't wane earl gettin' on the new shinneys!
Old 10-25-2013, 09:43 PM
RSR
RSR's Avatar
Doesn't look like shock fluid -- it's more of a light oil in my experience.
Could also be a failed inner axle seal -- the one that seals the wheel bearings that you're supposed to replace when replacing axles.
Old 10-26-2013, 07:45 AM
Stevesk88's Avatar
^ this is what i was thinking. If your in there you may as well do the seals for peace of mind.
88sasturbotoy
08-11-2015 01:56 AM
kirkrunner
07-27-2015 07:59 PM
gmonnie123
07-26-2015 02:44 PM
ksmudrunner99
07-21-2015 05:33 AM
1994toyota
07-17-2015 03:03 AM
Quick Reply: Control arm leak?
