Considering swapping my engine into broken 4x4
Old 08-31-2008, 02:07 PM
Duartizzle's Avatar
I have a 2wd 93 4Runner v6, i found a 4x4 4runner v6 that needs a new engine. How hard is it to swap the engine over? I would just need to swap the engine, ecu, and wiring harness right?
Old 08-31-2008, 03:26 PM
abecedarian's Avatar
if your only going to swap the block and heads, nothing else should be required.
There may be some variables if you're going to be bringing the manifolds and stuff over to the new truck though.
Old 09-01-2008, 10:41 AM
Duartizzle's Avatar
My plan is just the motor itself, would i have a problem with the ecu since it wont be for a 4x4?
Old 09-01-2008, 10:45 AM
76ANTHONY's Avatar
no because your just using the engine not the trans and 4wd.
voiddweller
19
05-02-2016 09:10 PM
God's Bounty Hunter
07-08-2015 12:54 PM
thelifeadventure
07-02-2015 03:09 PM
TheManOutside
06-18-2015 03:32 PM
Quick Reply: Considering swapping my engine into broken 4x4
