Connector to Sensor
if you can find a toyota truck with an engine still in there.
If not, what's a compatible setup with a different car??? I will go to pick-n-pull and find out.
or can somebody at least open up their hood and let me know... I would really appreciate it.
Which Wire Goes Where?
Well, it seems to me, you're going to have to go to pick-n-pull, anyway, to kit-up on the connectors and the leads (most 22R's have those specific plugs). And, with those in-hand, the answer will be manifest. Just match the leads.
Furthermore, it may not matter! Both switches are OFF, at norm op temps - when it's bubbling:
(It might affect warm-up and/or high temp operation.)
SmogTechs do not (usually) verify wiring harness color codes; they just wanna see everything hooked up. So, you gotta go to pick-n-pull, anyway, to get the hookup stuff.
Besides, htf do you describe that stuff? The red wire goes to the roundie-squarie plug, and the red wire with a gray or green stripe goes to the squarer plugin? Or what?
88yodabasket
07-13-2015 01:32 PM
