Computer problems or cold start injector? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-20-2008, 12:25 PM   #1 (permalink)
my 91 pickup will not start on a cold morning unless I leave a light shining on the computer that is located on the passenger side near the floorboard in front of the door.
Some have said this cold start problem may the cold start injector switch, but that is located on front of the engine. Are these two related????
Thanks
doogieboy is offline
Old 11-20-2008, 12:38 PM   #2 (permalink)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
I think shining the light may just be coincidental.
I would be looking at
A. Cold start injector timer (the sensor)
B. Cold start injector
C. Wiring
Wiring is prone to breakage, and i actually ran into a similar problem on my race car (1985 MR2) where it was a PITA to start when cold, but started first click when warm. I found the wiring for the cold start sensor was cut.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by space-junk View Post
DeathCougar, you know everything!
Quote:
Originally Posted by fustercluck View Post
Now I know DC is a leader.
DeathCougar is offline
Old 11-20-2008, 06:36 PM   #3 (permalink)
sloth!'s Avatar
First is the light a drop light that puts out decent heat? could be cold solder joint on the ecu board. The light keeps it warm enough to have good contact. cold and it contracts leaving a bad connection at the joint. Honda civics/accords have the same issue but with the efi main relay.
__________________
90 xcab, sased, arbs, 37s, marlin dual cases, warn, longfeilds, bobbed, ready for the mall.
94 4x4 DD
06 tundra CC 4x4
sloth! is offline
Old 11-20-2008, 06:48 PM   #4 (permalink)
bigt's Avatar
MY RUNNER did this for 2 winters ONLY WOULD START PARKED IN GARAGE...
turn out to die one day and it was ignition module/ignitor after i tried EVERYTHING!!!!!!!
__________________
1991 HILUX SURF SSR-X turbo diesel right hand drive toyota imported in 2005 from japan,
130,000 km 31 bfg a/t auto
current build
1987 LWB suzuki samurai. turning 2 into one.. yota axles welded front to back, yota springs , ifs steering box,, this bad boy will not only eat jeeps but toyotas aswell \m/
bigt is offline
Old 11-20-2008, 06:50 PM   #5 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
I'm leaning along the lines of sloth! here, that the heat from the lamp may be compensating for a cold solder joint. However, it could be a corroded electrical connector anywhere that same area and the heat from the lamp is masking the issue.
IF you are finding it easier to start cold ONLY when you heat up the passenger side area, look for corroded connectors (may be caused by leakage from the heater core) in that area.
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Computer problems or cold start injector? doogieboy 86-95 Trucks & 4Runners 3 11-21-2008 10:52 PM
3.4 cold start injector? fasthorse67 95.5-2004 Tacomas & 96-2002 4Runners 3 10-28-2008 08:27 PM
Cold Start Injector 4x4countrygirl 86-95 Trucks & 4Runners 14 02-16-2007 05:34 PM
i need a cold start injector 89macrunner 95.5-2004 Tacomas & 96-2002 4Runners 3 07-07-2005 06:48 PM
cold start injector SlimJim248@earthlink 95.5-2004 Tacomas & 96-2002 4Runners 3 06-29-2005 08:58 PM
2009 InternetBrands, Inc.
