compatible axles?
compatible axles?
Im getting alot of axle bind and it occasionally locks up under slow speeds so im looking for a new one....
this guy on craigslist has an rear axle says its out of a 80's model 2WD automatic(claims 4:30) gears... will this fit/work under my truck? (i don't know the year or size engine yet... waiting for call back)
my truck: 1989 22re 4x4 excab 5sp. thanks
Where are you located? I have at least one of what you need in my garage.
4.30s are from trucks with automatic transmissions-only. Provided your axles haven't been messed with, you have 4.10s.
http://home.4x4wire.com/erik/diffs/
You can usually find what you're looking for well under $200, depending on where you live.
okay thanks for the input i figured there was a diff in the 2wd and 4wd axles and yes i do have 4:10's i was planing getting gears anyways i planned on picking up the axle if it fit he only wanted like 100$.... i located in SC
justdifferentials
14
06-11-2017 08:36 PM
FS[MidAtl]: fZJ80 9.5" rear axles w/ e-lockers complete
I8URSVT
10-05-2015 07:23 PM
