Cold Start Switch covered in oil???
Old 02-26-2012, 11:37 AM
cwalstad's Avatar
I posted this in my build up thread but got no response... I'd really appreciate any suggestions you may have.
I was under the hood the other day and noticed that directly under my EFI tube (45 degree elbow), the wires (i think it is the cold start switch) are covered in oil, and the bottom of the elbow it is caked with dry oil and grease. Suggestions???
Everything is wet and gross.
You can see the rest of my build @
https://www.yotatech.com/forums/f199...r-22re-249585/
Old 02-26-2012, 01:09 PM
paintthetown's Avatar
Take the elbow off and degrease that area. Make sure to cover intake and alt. Run the Runner and keep checking that area for leaks.
Old 02-26-2012, 01:17 PM
cwalstad's Avatar
I just don't understand where the oil would be coming from in that area... from behind the switch?
Old 02-26-2012, 01:27 PM
Do you know for sure it's oil and not coolent? Put your finger on it and smell. Both sensors there have coolent going to them.
Old 02-26-2012, 01:31 PM
cwalstad's Avatar
I'm pretty sure it is oil on the elbow, the wires could be coolant... It just seems strange that the wires in the switch are wet... like something above them is leaking, but when i investigate it, there is no leak... is there a way that the switch could be leaking?
Old 02-26-2012, 01:58 PM
If the cold start switch was leaking it would be coolent. I'd clean it all up, dry everything run it up to operating temp. While its idling look for any leaks. If you don't see anything, dive normal for a few days and then check.
Old 02-26-2012, 02:05 PM
cwalstad's Avatar
Thanks man... will do. I'm parting out my 87 tomorrow so it'll be a bit before i get to it but i'll update you.
Old 02-27-2012, 06:17 AM
xylicon's Avatar
I had that same problem, my temp sensor and the cold start time switch covered in fresh oil. I later found out that it was coming from the mechanical fuel pump block off plate. I replaced the gasket and no more oil (:
Old 02-29-2012, 03:15 PM
cwalstad's Avatar
Thank you so much... I will change that soon.
Team420
01-12-2021 04:57 PM
jennygirl
11-17-2015 11:24 AM
jmc88runner
06-18-2015 03:39 PM
scott
07-15-2002 07:56 AM
Quick Reply: Cold Start Switch covered in oil???
