cold start sensor - YotaTech Forums
Go Back   >
cold start sensor
LinkBack Thread Tools Search this Thread
Old 10-06-2008, 07:40 PM   #1
ontario4runner's Avatar
Question cold start sensor
ok.. so my cold start sensor is soo rotted out the connector fell off.. the connector is in good shape still though thankfully
anyways i spent all day driving around(with my now even crappier running truck) annd no one has even heard of this.. would it be best to just get the sensor from toyota? and has anyone ever bought one from them, or know price wise how much they run for?
i need to get it done soon as its cold up here in the great white north and my truck is sooooo hard to start without it.. also making it run like crap(high idle)
so any help would be great
ontario4runner is offline   Reply With Quote
Old 10-06-2008, 07:43 PM   #2
jason191918's Avatar
Quote:
Originally Posted by ontario4runner View Post
so out of curiosity.. ill be picking up my cold start sensor monday and putting it in.. any words of advice for getting old one out and new one in? its a pretty tight space! haha
What happened to that one?
jason191918 is offline   Reply With Quote
Old 10-06-2008, 07:44 PM   #3
This one time, at band camp
Staff
DeathCougar's Avatar
Just buy a new sensor from Toyota. The plastic they used in the building of them gets hard and crumbles. Typically it can be had for under $100. If you can still see the part number on the side of the sensor, go to www.toyotapartsales.com and input the number to get an idea of what they run brand new.
DeathCougar is offline   Reply With Quote
Old 10-06-2008, 07:48 PM   #4
Quote:
welll.. i had called the autoparts store i was going to get it from.. as i have an account with them.. and they said they had it.. turns out when i went to get it they thought i was stupid and meant coolant temp sensor and they argued with me saying there is no such thing as a cold start sensor in my 4runner.. i soon shut them up with my handy dandy toyota service manual needless to say.. every parts store i go to says the same thing.. there is no such thing.. even reading threw there lists myself for even alternate naming...
Old 10-07-2008, 01:52 AM   #5
Cold Start Injector vs. Injector Timer
The actual temperature sensing of your motor is done by the Injector Timer that sends a signal to the the Cold Start Injector, once up to operating temperature there should be no use of the Cold Start Injector when starting. I had the same issue, cleaned the injector and it worked for a time, but then same cold starting issues would return. I know you're not going to want to hear this but what fixed it for me was a new fuel pump, apparently there's a check valve in the pump, and when your truck sits idle the fuel drains back to the tank, therefore when you start your truck it's like you have to crank it until the fuel comes all the way from the tank. Replaced the fuel pump, not a problem, even after the truck sits for a month (...in Minnesota). Good luck.
BrownsfaninMN is offline   Reply With Quote
Old 10-20-2008, 07:32 AM   #6
waskillywabbit's Avatar
Quote:
I got one doing exactly this...was not doing it before in another truck so I am thinking the fuel pump.
So which is cheaper to try...the CSI or timer or a fuel pump?
waskillywabbit is offline   Reply With Quote
Old 10-20-2008, 10:54 AM   #7
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
I had to replace the CSI in my old '91 3.0 truck and IIRC it cost me something like $178 from the stealersip
a4runnerfreak is offline   Reply With Quote
87 22r rebuild issue bigjstang 86-95 Trucks & 4Runners 14 12-09-2016 10:16 PM
ENGINE TROUBLE 3vze please help :( smiley52 86-95 Trucks & 4Runners 8 07-11-2015 06:16 AM
2000 camry wont start Huntingtruckcletus Other Makes Cars/Trucks 0 07-08-2015 06:26 PM
speedometer 'freaking out' wilbertd 86-95 Trucks & 4Runners 2 07-06-2015 08:39 AM
22rte troubles karbin Newbie Tech Section 1 07-06-2015 12:37 AM
Tags
4runner, 86, 95, cold, cost, injector, number, part, prices, runner, sensor, start, starting, tacoma, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
