Cold Start Injector - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-16-2007, 09:37 AM   #1 (permalink)
4x4countrygirl's Avatar
Send a message via AIM to 4x4countrygirl
Cold Start Injector
My boyfriend's 88 runner has been starting rough ever since it got cold out. The gas mileage is horrible (about 100 miles per tank in a V6 16 gallon tank) and it sounds pretty bad when you rev the engine. Once it's warmed up, it runs fine again. So, from reading other posts, we are pretty sure it's the cold start injector. Does that sound right?
Anyways... we are going to be working on the truck this weekend and decided that if we could, we would like to replace the cold start injector too. However, we need some help and direction on how to do it. Anyone have some ideas as to how we should go about replacing it? We're not really sure where to start... we have the Haynes manual to go off of and that's about it. Thanks!
__________________
'94 Pickup
22RE/5sp/4x4
4x4countrygirl is offline
Old 02-16-2007, 09:54 AM   #2 (permalink)
rdlsz24's Avatar
Send a message via AIM to rdlsz24
6 miles per gallon? lol. Do you already have the link for the FSM?
http://personal.utulsa.edu/~nathan-b...88coldstar.pdf
I like to use a combination of it and a Haynes or Chiltons.
Rob
__________________
1988 Xtra Cab Pickup ('94 22RE; 4x4; 5spd)
Rancho lift w/ 33x12.5x15 tires & 5.29s
rdlsz24 is offline
Old 02-16-2007, 09:59 AM   #3 (permalink)
linuxrunner's Avatar
sounds like cold start injector try...
http://www.yotatech.com/showthread.p...start+injector
or FSM page here:
http://personal.utulsa.edu/~nathan-b...ne/97colds.pdf
Good Luck, I don't have the 3.0, but maybe try unpluging the injector and see if it gets better.
(looks like Rob beat me, the link he gave you i think is for the 22re tho)
__________________
88 4runner 22re
Quote:
"Ditch that IFS because it is already crap and go for an SAS! (Single Axle Swap)"
linuxrunner is offline
Old 02-16-2007, 10:15 AM   #4 (permalink)
Robrt32's Avatar
Rob
That link there ive seen it in a few threads and my puter does not open it.. I just have a blank screen.. I'm not very puter literate , what am i lacking to veiw it?
Robrt32 is offline
Old 02-16-2007, 10:23 AM   #5 (permalink)
deathstalker's Avatar
adobe acrobat reader. if you do have acrobat installed, try doing a save as, save it to your desktop, then open it from there.
__________________
'87 pickup 22r std - new to the game, any advice would help out ;)
deathstalker is offline
Old 02-16-2007, 10:42 AM   #6 (permalink)
rdlsz24's Avatar
Yeah you need Acrobat Reader. It's free: http://www.adobe.com/products/acrobat/readstep2.html
Rob
__________________
rdlsz24 is offline
Old 02-16-2007, 10:46 AM   #7 (permalink)
Turd Ferguson's Avatar
Send a message via AIM to Turd Ferguson
Few months ago my CSI malfunctioned and dumped several gallons of gas into the motor (it was backing up thru the exhaust manifold). The wire in the harness that controls it corroded and it wouldn't shut off. My mechanic traced the problem down, and bypassed it. I've been running without it for about 3+ months.
On cold starts it takes a little to crank it over, but a squirt of starter fluid and it fires right up. It idles high (around 1800 rpm) for a few minutes then drops down to around 1K RPM and eventually settles to normal after the oil gets going.
The ĊĊĊĊty gas mileage is a problem, though. Seafoam the motor and see if it improves any.
__________________
1990 4Runner V6 SR5, "The Porkchop Express"
http://www.yotatech.com/f108/fs-1990...e-area-167493/
NOW FOR SALE!!
2004 Tacoma V6 SR5 TRD
See the Misc Forum for my parts for sale!
"I'm just like every other normal guy, except I hit the speedbumps at 50, sometimes 60 miles per hour."
Turd Ferguson is offline
Old 02-16-2007, 10:47 AM   #8 (permalink)
Robrt32's Avatar
I saved it too desktop and saw it fine.......Thanks alot...I learned alot from it
Robrt32 is offline
Old 02-16-2007, 10:49 AM   #9 (permalink)
Robrt32's Avatar
Rob
Thats the way i have to crank mine now with starting fluid... It runs fine and gets around 27 miles to the gallon.. but it would be nice not having to pop the hood every cold morning
Robrt32 is offline
Old 02-16-2007, 10:57 AM   #10 (permalink)
We have seafoamed the engine and not much change if any. It actually is a completely rebuilt engine that we replaced just this last summer. So, new engine but all the rest are old parts... is there anything else that be causing such a HORRIBLE gas mileage problem that we should be looking into?
__________________
'94 Pickup
22RE/5sp/4x4
Old 02-16-2007, 11:42 AM   #11 (permalink)
I also forgot to ask about how long it would take to replace the cold start injector? How much work is involved?
__________________
'94 Pickup
22RE/5sp/4x4
Old 02-16-2007, 12:56 PM   #12 (permalink)
Marc's Avatar
Quote:
If it's the 3.0 it takes 5 to 10 minutes to replace.
The hardest part is getting the clip off the connector.
__________________
'91 4Runner SR5 V6 4X4 Auto, A/C, 4.56, 31x10.5x15 Nokian Vatiiva Tires, Taurus fan (removed)
'90 4Runner SR5 V6 4X4 Auto, A/C, 4.56
V6 power with V8 fuel mileage
I've used Fram oil filters and dino oil in all my stuff for 30 years and never had trouble
I bet MOST people who say "swap in a 3.4" have NEVER changed any engine nevermind converting to a different type
Marc is offline
Old 02-16-2007, 02:00 PM   #13 (permalink)
Chapman88SR5's Avatar
Send a message via AIM to Chapman88SR5
Can anyone describe or show me a picture of where the CSI is?
__________________
1988 4Runner 3.Slow
-33x12.5 Mickey Thompson Baja MTZ Radials
-4Crawler 1.5" BJ Spacers
-OME 2" Leaf Springs
-Flowmaster 44
-Engine replaced at 200k
-Green Rattle can paint
The early bird gets the worm but the second mouse gets the cheese. Hmmm...
See more in the Check out my Truck section
God works through Christians; I am a Christian.
-George W. Bush
Chapman88SR5 is offline
Old 02-16-2007, 05:25 PM   #14 (permalink)
^VooDoo^'s Avatar
Another way to check if the coldstartinjector or the enginetemp sensor, Take the plug off the CSI, If its harder to start then the CSI is fine, If no change then It may be the Enginetemp sensor, Thats on the backside of the engine and its the one on the left.
This is also a symtom of a O2 sensor not working or warming up, Check its harness and plug.
^VooDoo^ is offline
Old 02-16-2007, 05:34 PM   #15 (permalink)
SoCal4Running's Avatar
Is it not possible that the CSI is just plain leaking even when the plug is disconected????Hence the bad MPG.
__________________
'86 4runner
22RE, 5-speed, LC Street EFI head w/ cam, LC Pistons, ARP Head Studs, Downey header, Dynomax 2 1/4" full exhaust, VDO water temp guage, 01-03 Tacoma cd\tape radio with 10" Bazzoka, Downey 2" rear springs, GDI radiator, Torus fan DONE!!!!
'68 Ford Mustang Fastback
Daily driver with a built 289 and a streetfighter trans.(Retired)
98 Subaru Outback-Took over daily driving duties
MicroMatic.com
Waco93.com
SoCal4Running is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
cold start injector ELD 86-95 Trucks & 4Runners 9 01-07-2007 11:32 PM
i need a cold start injector 89macrunner 95.5-2004 Tacomas & 96-2002 4Runners 3 07-07-2005 06:48 PM
cold start injector SlimJim248@earthlink 95.5-2004 Tacomas & 96-2002 4Runners 3 06-29-2005 08:58 PM
Cold Start Injector? 86 TurboSR5 95.5-2004 Tacomas & 96-2002 4Runners 0 07-22-2004 07:34 AM
cold start injector? grafix43 95.5-2004 Tacomas & 96-2002 4Runners 8 02-19-2004 08:27 PM
2009 InternetBrands, Inc.
