cold start
Old 12-09-2008, 04:05 AM
91 yota's Avatar
cold start
is there a adjustment on the idle when the motor starts up cold? when the motor is up to temp it does idle at bout 800 rpm and thats 50 rpm above what it is suppose to. when it starts up cold it jumps to 1650 rpm. then after it warms up it goes down to 800. i just don't like it jumpin that high first thing in the morning.
Old 12-09-2008, 06:21 AM
rdlsz24's Avatar
Cold start high idle is normal. I think mine is close to 2k rpms when stone cold.
Rob
Old 12-09-2008, 10:11 AM
abecedarian's Avatar
the cold start idle speed not adjustable. also, the colder it is the higher it will idle. depending on the year, the auxilary air valve may be electrically heated or heated by coolant.
you can turn the screw (about 1/2" diameter) on top of the throttle body to lower the warm idle to 750.
Old 12-09-2008, 11:23 AM
Tubbyfatty's Avatar
Around 40* F or so my truck idles around 1500 when cold.
Old 12-10-2008, 06:45 AM
rangerruck's Avatar
on my 88' , I have that big plastic screw, that is spring loaded, on top of the efi box, turned all the way down. so far the idle is 700 rpms. It has not gotten cold here in Houston yet, but it will be starting today, so when I get it out of the shop, I will check that out, to see if the cold start goes to a higher rpm.
Old 12-11-2008, 07:34 AM
mxridercrf450r's Avatar
Do you have A/C? I'm pretty sure that is for the A/C idle up relay
Old 12-11-2008, 04:38 PM
rangerruck:
with a/c, that 'big plastic screw', the a/c idle up valve, is used to set the idle speed when the a/c compressor is on so that the drag from the compressor doesn't cause the engine idle speed to drop too low, causing ineffective a/c operation at idle. if adjusting that screw with the a/c off mucks with your idle, somethings wrong with your truck, likely the VSV associated with the a/c system is malfunctioning.
Old 12-12-2008, 01:54 PM
GVOLCRunner's Avatar
Cold Temp, high idle is normal. Its there to speed up the cold lubrication quicker. As long as you have the proper weight oil 10w-30 you are fine. I would wait till it idles down to move..
Old 12-13-2008, 04:46 PM
Jay351's Avatar
Normal. I just wait till the idle drops down to about 1,000rpm. Or untill the thermostat opens up, then I go
BushPig
10-29-2022 06:26 AM
bigjstang
08-25-2021 12:41 AM
Doug4320
03-24-2018 10:11 PM
Jonny246
07-12-2015 04:51 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: cold start
