Which Cold Air Intake Should I Buy
i would recommend Downey or K&N. if you take care of the filter, it will perform great. if you dont look after the filter, you will become a hater of cold air intakes because it wont perform good.
There will probably be a few people that say don't even bother buying an aftermarket intake kit. They may tell you to just buy a better filter to replace the stock element.
That's fine.
I went with a K&N kit for my 22RE about ten or so years ago and I've never had a problem. I can feel a difference in performance, even if it is a small one.
I even purchased a kit for my 3.4 litre and I think it's bad ass. I also went against suggestions from "friends" who said the K&N's are worthless.
If that was so true, why has K&N been around for 25+ years...if they were really that bad of a mod, you would think they would be out of business by now.
That's fine.
I put a K&N on my '91 V6 about 6 years ago. I was immediately happy with the results and still am. As a matter of fact, I just pulled it off yesterday to clean the filter. That's the key....keep your filter nice and clean and you'll feel/hear the difference.
Whoaa...sweet looking rig you have there.
I just ordered a kit off ebay that comes with the MAF adapter and all. I mainly wanted it for the intake tube itself instead of using PVC piping or something. I'm gunna throw a K&N on the end, and keep the cheapo rice-burner filter in the tool box as a spare.
Don't use the cheapo. Just get rid of it. Why treat your engine to a no name semi-filter. Cleaning, drying and re oiling your KN doesn't take that long.
just goes to show - marketing trumps build quality.
Thats a great quote....and pretty much true...
What K&N doesnt tell you is that the increased air flow = increased dirt flow (especially with a filter like K&N that is substandard micron wise to a Toyota paper filter)
I consider these to be engine-killers....is the increase in butt-o-meter dyno performance (which is negligible from what I have seen) worth more than the decrease in engine life?
If not most of the gains would be received from a K&N replacement fIlter.
Right now I an working on making a fresh air intake for my truck, (making stuff is just my way)
I'll post once I get it together, That's about $150 in materials away right now though.
My personal thoughts on this topic are that the stock location for where
the filter draws its air is the best place. It is high enough to avoid hydrolock
in most situations, while still providing the engine with cold air.
What I would do in your situation is buy a cheapo ebay 'cold air' intake.
Install the tubiung they give you. Throw away the cone filter, get a K&N
drop in element for your stock air box and just reuse the stock box.
That way, you get rid of the intake silencers but still retain the effectiveness
of the good parts of the stock system.
The other thing I like about using the type of intake setup that does away with the stock box by using the AFM adapter is that when I go to make my own snorkel later on, it'll make things a lot easier!
I agree with nix4x4 "cold air intakes" are taking air from the engine compartment while the stock location is behind the headlight taking in true fresh air. ISR mod will help for sure but the stock location is about as "cold" and fresh as it gets without gettin a snorkel which is what i am thinkin of doin.
nanhodges2733
05-29-2020 03:28 PM
