Coils & Torsion Bar Recomendations
Old 04-25-2008, 11:53 AM
Hilux808's Avatar
I need some opinions on torsion bars and rear coils for my 91' 22RE 4Runner...
After researching I think I have decided on Downey for front and rear suspension. I figured, or at least have been hearing that Downey sells some pretty good stuff for Toyota's and that I could just order both from the same place. I looked up Swayaway and NWOR as well. I don't have a lift, just want to replace with better bars/springs. Anyone running Downey and are you happy with them? Do their rear coils really lift 1.5" from stock?
Any other brands you guys like or recomend?
Old 04-25-2008, 12:53 PM
Belize Off Road Team's Avatar
OME. i wouldn't recommend anything else to any body. OME has proven track records with the Dakar Rally. when i replace my suspension with SAS and coils all around, OME is where i'll buy what parts i can.
Old 04-25-2008, 01:17 PM
hurley842002's Avatar
x2 on the OME.
Old 04-25-2008, 01:19 PM
tc
tc's Avatar
Just leave the tbars stock. Aftermarket bars are just higher spring rate (ie stiffer) and make the ride and "flex" suffer accordingly.
I would go with the Eiback or PP progressive rate coils in the back. I did the Eibachs and they're great IMHO.
Old 04-25-2008, 01:20 PM
Hilux808's Avatar
Is that Old man emu?
Old 04-25-2008, 02:40 PM
sleaz22xx's Avatar
Yup thats old man emu, there is a guy on this board that can help you out, check out TRDparts4u.com
Old 04-25-2008, 02:43 PM
norcalsvx's Avatar
i run the OME torsions (bigger than stock but not as big as some others) and they work great-
Old 04-25-2008, 02:48 PM
Matt16's Avatar
Old Man Emu rear coils and stock torsion bars. Torsion bars last pretty much forever. Some people have said Downey coils sag really fast. I have OME and I like them BUT...if you run the OME springs, the ride won't be good if you go with a cheap shocks like a ProComp. OME springs are very stiff and the OME shocks are soft, so together they work well.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
choppe777
05-16-2016 08:00 AM
Scottcrb
03-03-2016 11:57 AM
gyroscope7
09-13-2015 05:15 AM
HiLuxer
09-09-2015 02:43 PM
Quick Reply: Coils & Torsion Bar Recomendations
