code 52. need shielded wire?
Old 10-27-2010, 05:06 PM
frankenstang91's Avatar
I believe I have a wiring problem on the engine harness side of my ks connection. I replaced my worn/damaged ks pigtail and sensor but still get the dreaded 52 code. Since the sesnor and its pigtail are new all that is left is the engine harness and ecm ( which i've tried with a used donor) where can i get the shielded wire people speak of? (I read the code 52 tech thread) I have run a new signal wire from the ecm to the pigtail. I dont know how to fix the shielded portion of the circuit. This is on my finace's grocery getter 1995 4runner 2wd 3.0 all original with 189,xxxmiles. Oh by the way, hello YOTATECH! from Ga.
Thanks in advance
Justin
Old 10-27-2010, 08:23 PM
so i acquire the shielded cable, ground it, and attach the other end to the brown wire going to the ks pigtail. is that correct? signal = black and ground (shielded) = brown?
smthwsn357
12-04-2023 02:08 AM
raptor510
02-17-2017 07:11 AM
nonstop
07-24-2015 06:29 PM
smiley52
07-11-2015 05:16 AM
Quick Reply: code 52. need shielded wire?
