code 52 knock sensor
Old 03-23-2008, 01:12 PM
injun's Avatar
ok before posting here i did do a forum search on this issue to no avail
i have 91 4runner with 3vz-e that gives a code 52 (knock sensor) fault.
could someone tell me where it is located? i have chiltons manual but it doesnt say.
hopefully it is just dirty or sumthin, darn thing is 157 bux
Old 03-23-2008, 01:18 PM
mr_schuster's Avatar
Between the cylinder heads on the block, under the manifold.
Old 03-23-2008, 01:37 PM
injun's Avatar
so what yer sayin is that since i have a new shiny pcv valve now is the time to change that too?
Old 03-23-2008, 01:53 PM
Dont forget the grommet. The knock sensor has a single wire running to it, usually they are very brittle and can become a problem. If you have in mind to replace the sensor, order the wire as well.
Old 03-23-2008, 05:34 PM
mntgoat's Avatar
What size socket fits the knock senser?
Old 03-23-2008, 08:16 PM
Don't quite remember, I think I used an adjustable. They are usually not tight.
Old 04-28-2008, 10:34 AM
dirtyXplorer's Avatar
So you have to take off the plenum (sp?) to get to it?
When you take that off is there any type of gasket you have to replace?
i have a code 52 and I was also thinking of replacing the PVC while I was in there...
Thx
raptor510
08-19-2015 02:15 PM
rjtrials
08-06-2015 07:25 PM
nonstop
07-24-2015 06:29 PM
smiley52
07-11-2015 05:16 AM
Quick Reply: code 52 knock sensor
