Code 52: 89 22RE
Old 07-20-2011, 05:06 PM
dabineri's Avatar
Code 52: 89 22RE
I have an 89 pickup with a 22-re engine and am having the dreaded knock sensor problem. I have rewired the sensor to the ECU with shielded cable, grounded both ends of the shielding and soldered all joints. It still throws a code 52 after it warms up and little and the engine speed reaches a certain value. I have looked at the signal reaching the ECU on an oscilloscope so now I need someone who would be willing to do the same on the same engine and describe what they see with the engine at idle. I have been unable to find this signal anywhere and this should tell me if the sensor is working. You would be a lifesaver if you can do this! Thanks, Dave
Old 07-20-2011, 05:12 PM
toyotakid's Avatar
how do you get the engine lightto flash thecodes... sorry i cant be of help but im having problems and cant figure stuff out haha
Old 07-20-2011, 05:15 PM
dabineri's Avatar
Turn ignition switch off. Short TE1 and E1 in the little box next to the fuse box in the engine compartment with a paper clip. Turn the ignition on (don't start) and the check engine will start flashing the codes. This is for a 22RE. Dave
Old 07-20-2011, 05:51 PM
Fossilized
Staff
dropzone's Avatar
OP: i edited your thread title-Need a favor is the type of title that can lead to deletion w/o notice
Old 07-20-2011, 06:03 PM
toyotakid's Avatar
i dont have a TE1 and every one keeps telling me i do lol but a i have a T,and a E1. but that didnt work.
Old 07-21-2011, 08:23 AM
93YotaGuy's Avatar
Do a little research or download the FSM for your truck!
montanatruck
02-26-2017 07:07 AM
raptor510
08-19-2015 02:15 PM
Tacoma1313
08-17-2015 05:44 PM
nonstop
07-24-2015 06:29 PM
jake_v
07-22-2015 03:17 PM
Quick Reply: Code 52: 89 22RE
