Code 41 help
Old 12-07-2009, 05:10 PM
Boomin4Runner's Avatar
Code 41 help
I replaced my altenator and did the "big three" andmy car is still throwing a code 41 i reset everything as well any ideas
Old 12-07-2009, 06:50 PM
Team420's Avatar
Year/Make/Model??? I assume its a 86-95 4rrunner? code 41 is tps if I'm not mistaken.... maybe it needs replaced or adjusted?
Old 12-07-2009, 07:30 PM
what is tps??
Old 12-07-2009, 07:49 PM
Could this be caused by my intake having a hole in it????
Old 12-07-2009, 08:25 PM
2DoorRunner's Avatar
tps is the throttle position sensor. Where is the hole?
Old 12-07-2009, 08:37 PM
its in that black box it got to close to my headres and melted
Old 12-07-2009, 08:55 PM
the black box that is int he middle of the plumbing for the intake
Old 12-07-2009, 09:12 PM
abecedarian's Avatar
The throttle position sensor is just above the engine- that big piece of metal between the front tires that makes the truck go.
Just kidding.
Seriously though, it's on the throttle body, which is on the opposite end of the plastic tube that connects to the air filter.
Old 12-07-2009, 09:22 PM
i know what the sensor is the question is if i have a hole in that black box that connects the two pieces of 3 in plumbing for the intake will that set off the sensor
Old 12-07-2009, 09:27 PM
Nope. ... and I hope you get that I was only joking?
A hole in the intake duct would cause the engine to run like crap, if it even runs, and may throw a code related to the VAFM.
Old 12-07-2009, 09:30 PM
yeah im pulling a code 41 and i know you were giving me crap its 94 v6 3..(3.0)
Old 12-07-2009, 09:44 PM
would that cause me to pull that specific code or what
Old 12-07-2009, 09:52 PM
I already answered you.
Old 12-07-2009, 10:13 PM
Tracey98277's Avatar
you sir... need to do an ISR mod or go get a short-ram intake kit.
but yeah your TPS is probably jacked up try testing it... refer to the FSM. the tps problem is most likely un-related to the hole in your intake, which is causing a lean mixture unless you have it patched with something.
moparbay
10-06-2015 09:24 AM
bradahman
10-01-2015 09:24 AM
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
Draven023
09-26-2015 12:41 PM
Quick Reply: Code 41 help
