code 25 & 26 after new headers...help!?
Old 12-03-2007, 02:32 PM
doubledizzle's Avatar
Ok i have a 89 pickup with a 22re i put a header on it awhile back and now its throwing code 25 and 26...ive changed the water temp sensor and o2 sensor and its still coming up any help?
Old 12-03-2007, 02:48 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
See if there are any leaks around the gaskets....at the manifold and pipe. They can come loose after a bit of use from expansion and contraction.
Hang on to those old parts. They're probably still good. Make convenient back ups. I like to do that, anyway.
Old 12-03-2007, 03:01 PM
would that have to do with those codes its a rich lean code so??
Old 12-03-2007, 03:19 PM
thook's Avatar
Yes, it would.
Welcome to the forum, btw.
If air is getting into the exhaust prior to the 02 sensor, it will pick up on that as and incorrect exhaust gas mix and throw a code. In turn, the ECU will be constantly richening or leaning the fuel mix to compensate for the what the sensor is telling it. Not to mention, air can get sucked up into the head and possibly damage a valve....depends on how bad it is, though.
Take a long rubber hose and put one end to your ear and listen around the header and pipe connections for any hissing.
You may not have any leaks, but it's good place to start.
Old 12-04-2007, 04:47 AM
idanity's Avatar
also, your intake boot must not be cracked or have any gaps/holes, etc.
did you keep 0EM parts.
i bought a brand new cts (coolant temp sensor) from a auto store, only to find out it was faulty right out of the box,
3 days later, and every wire mapped (from ECU to injector harness) only to find the brand new sensor was indeed junk.
went to the dealer, and 30 minutes later, fired up, no problems since.
Old 12-04-2007, 11:27 PM
stormin94's Avatar
Check to make sure none of the wires are melted, or touching the headers. Make sure you put the header gasket on right, and tight. Maybe look into sheilding important stuff (starter, sensors, etc) from the heat of the headers. While it is true that headers reduce underhood temps, they generally radiate a larger amount of heat within a short distance than stock mainifold.
Old 12-05-2007, 02:48 PM
thanx u guys im gona give it a try and hopfully it will work....and another thing is i have the idle control valve bypassed it was a bad valve and had to bypass for the mean time....would that be throwing the codes?
Old 12-05-2007, 03:06 PM
TORTIS's Avatar
you cleared the codes and they came back?
Old 12-05-2007, 07:34 PM
yea the light comes on when all the readiness monitors set...
Old 12-06-2007, 09:48 AM
another thing can some one please tell me where i can find a bar that sum what like this.......
Old 12-06-2007, 09:51 AM
i cant find anythin under 1000$ its whack haha i have this 89 p/u that needs sum extra cover...and this is the bar ive been lookin for forever but cant find anything?????
Old 12-06-2007, 04:17 PM
thook's Avatar
Here's what the IAC valve does....you (we) have the VSV type.
http://www.autoshop101.com/forms/h60.pdf
Considering what it does, it can create fuel mix problems.
Old 12-06-2007, 06:18 PM
man thank you so much im startin to get things worked out with it.....this forum is amazing.......haha now if i could find that valve for less than 200 somthin dollars....
moparbay
10-06-2015 09:24 AM
bradahman
10-01-2015 09:24 AM
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
Draven023
09-26-2015 12:41 PM
Quick Reply: code 25 & 26 after new headers...help!?
