code 14 what is it?
Old 05-03-2008, 04:47 PM
94toy4x4fever's Avatar
code 14 what is it?
Have stored code 14. On a 94 toy 22re. Dont know what it is.
Old 05-03-2008, 05:12 PM
abecedarian's Avatar
It means 'a loss of IGF signal between the ignitor and the computer for 6 events'. In other words, the computer expected a signal that the plugs were firing but couldn't tell they did 'fire' or 'spark' for 3 rotations of the crank (6 spark events). More importantly, it means that the computer, for whatever reason, did not detect a proper 'spark' and 'combustion' event for a long enough period of time to signal a serious problem.
Most likely, it is the ignitor (the black box on the ignition coil) but could also be the wiring from the ignitor to the ECU or the ECU itself.
Are you experiencing any engine performance issues?
Old 05-03-2008, 05:22 PM
chrishf12's Avatar
I have had the same issue but it would come and go. I would like to know what you find your problem to be.
Old 05-03-2008, 05:26 PM
I dont have a loss of power but the truck does ping alittle bit. Even on high octane gas
Old 05-03-2008, 05:29 PM
Maybe I should back up a little and ask if the check engine light has come on at all recently?
It's possible that the code was triggered a while ago but hasn't happened since and is only showing up because the codes are stored.
Old 05-03-2008, 05:38 PM
check engine light came on a few months back. It was a code 71 egr. No this code was a stored code that I pulled after taking a drive. Just was curious to see if there was any stored codes.
Old 05-03-2008, 05:41 PM
Truck also dosent like to start after it gets hot. I have to crank it then wait the crank it again. It usually takes a little to get it fired. WHEN HOT. Fires right up when its cold.
Old 05-03-2008, 05:58 PM
If it's a 'stored code' as you say, I wouldn't worry about it. Like I said, it basically meant that the computer didn't detect spark plugs firing for a few engine revolutions. That is totaly unrelated to what you're experiencing now.
Hot start problems with fuel injected vehicles are usually related to fuel pressure regulators and check valves.
Old 05-03-2008, 06:06 PM
ok thanks man u have been great help!
Old 05-03-2008, 06:10 PM
Maybe a fuel filter change is in order.
Old 05-03-2008, 06:41 PM
put new fuel filter in when I put the engine in 2 months ago and it only got 1200 miles on it right now
moparbay
10-06-2015 09:24 AM
bradahman
10-01-2015 09:24 AM
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
Draven023
09-26-2015 12:41 PM
Quick Reply: code 14 what is it?
