| New! Use your Facebook to securely log into this site, click logo to login |
| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Clutch sticking to the floor?
#2 (permalink) |
if the rubber hose is leaking, you can swap it for another hose, but it should be rubber. if it is solid, the engine and body moves differently from each other and can break the line, reason for using flexible hoses
#3 (permalink) |
ok. well what would explain my pedal sticking to the floor and i have to reach down and lift it back up? just air in the line since its a hydrolic clutch?
#4 (permalink) |
lmao never heard of that happening...wow...
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE 1992 SR5 4runner V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous "Its still a toyota man.. Dont deprive it of its capabilities.." "If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009 |
#5 (permalink) |
Mine sticks to the floor but it's because the floor mat gets in the way.
AGHHH!!
__________________
'92 Yota 5 Speed V6 4X4 Had 5,000 ORIGINAL MILES now pushing 6,000 New 32X11.50 all terrains and some Bright lights. :) |
#6 (permalink) |
no mine sounds like a suction cup when i push it in.. and then i either have to pull it up with my foot or hand. then it pops back into place. its weird. i dont have the money to take it to the toyota guy over here in my hometown becuz he charges alot. becuz its hunting season everyones yotas are either breaking or he is doin tune ups for em.
#7 (permalink) |
The pedal should never stick to the floor cause there is a spring that pulls it back when you take your foot of it.... that spring is gone or broke. The rubber line needs to be replaced theres no messing around with "BS" rigging just replace it bleed system and be on your way.
__________________
"Why not stay OEM your truck will last longer?" "I love what you do for me Toyota." "Moving Forward." "If a yota can wiggle It ain't stuck." "No matter what you do that timing chain will beat the guidles(Dampers) 1v1." "(TTT) Toyota Tough Truck." |
#8 (permalink) |
oh ok, i didnt know there was a spring. is it suppose to be behind or above the pedal?
#9 (permalink) |
if your leaking clutch fluid (brake fluid) than your probably low on fluid. if you top it off, it should hold off for a few days till and leaks below the low mark. for now you can top it off, bleed it and see how it goes. if it is leaking really bad, than its best to just replace what is leaking
#10 (permalink) |
It hooks to the pedal on the front and hooks under the dash. Its hard to see and ya gotta get on your back to see it.
__________________
#11 (permalink) |
well when my pedal stuck and i made it home i checked the clutch reservoir to see how much fluid i had and it was full but i still didnt have a full pedal?
#12 (permalink) |
air in the lines could cause a poor pedal.
#13 (permalink) |
so i need to look for spring, put ne steel hose which i bought today, new rubber hose and fill clutch fluid and then bleed and i should be good to go
#14 (permalink) |
Sounds like it.
__________________
#15 (permalink) |
ok thanks yall for the help
#16 (permalink) |
ok so i looked today and the spring is there. but there is a rubber spacer goin through my firewall and a rob that ties into clutch pedal and it goes out of this hole. what is this/ it looks as if it is getting stuck in there could that cause the sticking of the pedal?
#17 (permalink) |
the cause of the sticking pedal is from the leak. fix the leak and the pedal shouldnt stick. sounds like your spring is worn out too...
| Tags |
| 1992, clutch, floor, pedal, replace, sr5, stick, sticking, sticks, stiking, stuck, toyota, truck, wrong |
