clutch squeak?
clutch squeak?
hey guys, lately ive been noticing a squeak in my clutch, it all works fine, and doesnt change anything, just squeaks when i push in the clutch, what could it be?
Mine does it, look under the dash at the clutch pedal assembly. There will be a torsion spring tucked up in there. I tracked my squeeking down to that guy, I lubed it but it only lasted a day. I just turn the music up higher
Those pedal brackets tend to crack. Look very closely at the firewall area of the bracket.
And to properly lube that spring you need to use the special grease for polyurethane bushings.
There is a small plastic bushing that fits over the pin that connects the master cylinder pushrod to the clutch pedal.
The bushing will break eventually, if you replace it the squeak will go away.
Robb
Robb
kawazx636
10-06-2021 03:03 PM
primordialbeast117
12-19-2015 12:23 PM
smilen724
13
11-08-2015 04:11 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
