Clutch pedal repairs question
Old 11-07-2015, 08:54 PM
AppalachianOffRoader's Avatar
So my clutch pedal bracket broke, just like seemingly everyone else's, in the same spot as everyone else's. I pulled it out, got it welded. So now that it looks almost brand new I'm almost ready to throw it back in.
I also ordered part number 55113-34010, which is the plate designed to support the firewall behind the clutch master cylinder. Does this part go behind the master cylinder inside the engine bay, or inside the cab and in front of the clutch pedal bracket?
I don't have the part on hand yet, but I'd like to know if I can go ahead and reassemble my cab/steering column etc...
Old 11-07-2015, 11:59 PM
wyoming9's Avatar
Red face
I myself would think behind the master cylinder against the firewall.
I can`t see pulling the clutch pedal bracket to install it on the cab side of the firewall.
I guess it would depend just how big it is
Although this is the first I heard of this part
Old 11-08-2015, 07:32 AM
I'm assuming it goes in between the master cylinder and firewall too, but I wasn't sure. It's basically a shim shaped like the bottom of the master cylinder, but wider to increase surface area.
You can google the Toyota part number and you'll find pictures. I haven't found any descriptions or write-ups on how to install it. I'm guessing I'll know when I see it. I just didn't want to wait to start putting things back together if I didn't have to hahaha
Timflav
11-10-2015 03:52 PM
Rmlamp
11-03-2015 08:23 PM
linedawg35
11-03-2015 03:54 PM
rap2me
11-02-2015 10:46 AM
fasterspider
10-18-2015 08:20 PM
Quick Reply: Clutch pedal repairs question
