| New! Use your Facebook to securely log into this site, click logo to login |
| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
'86 4x4 Standard Cab Mostly stock for now 31"s for a bit |
#2 (permalink) |
Check the clutch pedal bracket. They're known to crack which will not allow the clutch to fully engage.
__________________
Nate Hefty Hefty Fabworks- Custom Fabrication in Colorado 1993 3.0 Pickup - 4" lift, 33x10.50s BFG KM1s. 1995 4.5L FZJ80 - OME springs, Locked. Nitto Terra Graplers. |
#3 (permalink) |
I did take a look at that and can't see anything. I got as far as I could under there with a flashlight and pushed the pedal by hand to watch and didn't see any type of flexing in the bracket.
__________________
#4 (permalink) |
i had the same issue it was my slave cylinder on in the engine bay/passanger fenderwell
#5 (permalink) |
Replace the slave cylinder on bell housing, they are cheap. I've had to do mine a few times.
#6 (permalink) |
That's the next step is replacing that slave. They don't cost that much and I figured since I changed one, might as well do the other.
__________________
#7 (permalink) |
ya mine was 15$ or somthin stupid
#8 (permalink) |
I noticed y
__________________
1989 V6 4x4 X-Cab 5spd 283k miles, Borla cat-back, K&N Filtercharger, 30x9.5 Bridgestone Dueler A/T REVOs Last edited by sb5walker; 01-05-2010 at 01:24 PM. |
#9 (permalink) | |
Quote:
#10 (permalink) |
Got the problem solved. After I took off the old slave, the pushrod had hardly any pressure compared to the new one. Now it's just messing around with the pushrod on the master for any adjustment. This has been an almost 2 year project (the whole truck and engine swap) and yesterday was the first time I drove it since I bought the truck. Now all that's left is getting the timing set, which it idles really fast and on my test run I had to start in 2nd gear. Then dropping the gas tank and fixing that problem. But to get back, yes it was the slave cylinder that was giving me issues. Sorry for the rambling.
__________________
