Clutch not popping back to full height.
92 - 3vze
Hey guys, I replaced the master and slave cylinders about 4 months ago, but ever since the clutch pedal won't quite pop back up the whole way to the top. I can shift pretty easy, but sometimes I have to pull the pedal to the top (the last inch or two) with my foot.
Is this a bleeding issue, or is there a little spring that makes the pedal pop up?
Should I bleed the clutch system again?
Thanks guys
Steve
Thanks guys
Steve
I would start with bleeding it. Then I'd crawl under and make sure your slave cylinder is extending and retracting properly. It might be getting hung up on something.
There is a return spring. Inspect that. Make sure your clutch pedal is adjusted properly, too.
http://personal.utulsa.edu/~nathan-b...sm/clutch.html
i had the same problem theres a bracket that all the pedal mount on then that mounts to the fire wall mine had a crack in the mettal were the clutch pedal is i just welded it back and braced it because the nutt broke too
06-01-2021 01:51 PM
