Clutch master cylinder
Old 01-09-2008, 08:25 PM
Sonofmayhem's Avatar
Ok i put a new one in my 86 turbo 4runner. I went to bleed it and nothing..... No pedal whatsoever. I pumped it over 100 times and it didn't build pressure at all. Whats up with it?
kthxbye
Old 01-09-2008, 08:32 PM
RobD's Avatar
I assume that you have a bleed screw at your slave cylinder that you opened...
Old 01-09-2008, 09:20 PM
apalmer1's Avatar
x2, is the bleeder valve open at the slave cyl? If its closed and your still not building pressure check the fluid lines into the master cylinder and into the slave cylinder. Then check the seal on the new master cylinder and make sure its not bad right out of the box. If all that is good and you are still getting no fluid pressure check if you are loosing any fluid at all. If so check out the hardlines and softlines completely and figure it out. Why did you replace the MC in the first place? are you sure it wasnt really an issue with the slave cylinder instead?
Old 01-09-2008, 11:45 PM
"pete f passed away quietly in his sleep on July 13, 2008
pete f's Avatar
Also check your pedal height off the floor angle .It should be 6 inches. If it's not check for cracks in your pedal bracket. If bracket is cracked you will think you have no clutch.
Old 01-10-2008, 01:01 PM
my4runner's Avatar
Clutch
Start the truck, let it heat up, then try pumping the clutch.....make sure all bleeder screws are tight first......
Old 01-10-2008, 03:59 PM
soarerjzz30's Avatar
Same thing happened to mine. Turned out it had a small leak under the cup, took it back to Autozone and got an oem one.
Old 01-10-2008, 05:35 PM
I replaced it because the other one was leaking into the cab. And it wouldn't hold pressure. Do you have to bench bleed these?
Thanks for the advice.
Old 01-10-2008, 06:22 PM
pete f's Avatar
I gravity bled mine. open the bleeder at the slave and let it slow drip for an hour close the bleeder and your good to go.
Old 01-10-2008, 06:53 PM
pete f's Avatar
gravity bleed
89-4runner told me about it in this thread.https://www.yotatech.com/forums/f116...-system-112974
It worked really good for me on clutch and front brakes.
Old 01-11-2008, 04:53 AM
mtrdrms's Avatar
Definatly invest in a suction bleeder kit. It takes about a minute to bleed the clutch master and its DEFINATLY bled. Also great for bleeding brakes which people neglect all too often.
09-04-2015 09:27 AM
bfmcelroy
08-18-2015 06:42 AM
sqdg71
08-07-2015 01:03 AM
wolfpackfan33
08-02-2015 03:36 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
Quick Reply: Clutch master cylinder
