Clutch installation - backwards?
Installing autozone clutch on my 1989 22re 4runner. Is there a certain way the disc has to go in and how do I know which way is the right way? I noticed one side is flatter the other side has the inner disc with the springs is raised. Also, in another post I asked about oil in the bellhousing. I did the rear seal, should I do the front trani seal also?
Thanks!
Thanks!
Because the Duralast clutch is likely made by the same company that made the OEM. I got a Duralast for my truck a few years ago that was made by Valeo, the same company that makes many of Ford's passenger car clutches. I don't know if Luk made the factory Toyota parts, but that's what came out of my truck.
Regarding the orientation of the disc, it should be marked on one side. If not, generally the flattest side goes toward the flywheel and the taller side toward the pressure plate like cchinny said.
09-04-2015 09:27 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
