Clunking vibration when turning?????
Old 08-03-2009, 06:24 AM
djrazr's Avatar
Unhappy Clunking vibration when turning?????
On my way to work, on even slight turns i was feeling and hearing a lound clunking sound, and the truck would vibrate. When i'm going straight, it's fine. It scared me, but i made it work safe
Where do i start?
Thanks
95 4x4 SR5
Old 08-03-2009, 06:30 AM
Fossilized
Staff
dropzone's Avatar
bad CV
Old 08-03-2009, 06:32 AM
djrazr's Avatar
A cv? I'll have to check to check it out because this was loud, like something was gonna fall off
Old 08-03-2009, 06:34 AM
Lumpy's Avatar
They can make quite the racket and vibrate like mad when they decide to go.
Old 08-03-2009, 08:19 AM
djrazr's Avatar
Do now do i replace the boot, or should i just replace the whole half shaft?
Old 08-03-2009, 08:26 AM
desertcamper67's Avatar
Have someone rock the steering wheel back and forth (engine running) while you or someone with a little knowledge looks at your steering linkage,bushings,ball joints,steering gear or rack for independent movenent. Something might show up shifting under the load. This is how I used to find bad parts that others couldn't.
I don't suggest driving it until you are sure it is safe. Bad CV joint is fine to drive on unless it affects your steering.
Good luck.
okamikai
04-30-2018 10:19 PM
lectric80
08-11-2015 12:02 AM
gillesdetrail
08-03-2015 04:43 PM
ripp96
07-25-2015 02:32 PM
Hamonacracker
07-17-2015 08:33 AM
Quick Reply: Clunking vibration when turning?????
