Clunking-Grinding noise only in reverse when wheels are turned sharp - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 02-07-2009, 09:23 AM   #1
1. For some reason, when I cut the wheels real sharp and back up, I get a clunking and grinding sound. Anyone know what this is?
2. Also last week, I locked my hubs in case I had to use the 4WD in the inclement weather and I had a real loud intermittent squealing sound coming from the right front wheel. When I unlocked the hubs, the sound went away.
ThomasTedder is offline   Reply With Quote
Old 02-07-2009, 09:29 AM   #2
This one time, at band camp
Staff
DeathCougar's Avatar
the clunking grinding sound is likely the steering stops. Very common, and very easy to fix problem. See your local dealer for new steering stop bushings.
As for the squealing, i am not 100% sure. Sounds like you have a hub or bearing issue though.
DeathCougar is offline   Reply With Quote
2001 Truck slamming into D and R! HELP PLEASE! mengquis 95.5-2004 Tacomas & 96-2002 4Runners 1 07-13-2015 11:39 AM
No power to the wheels and a horrible sound mlavery85 Newbie Tech Section 3 07-12-2015 11:33 AM
ENGINE TROUBLE 3vze please help :( smiley52 86-95 Trucks & 4Runners 8 07-11-2015 06:16 AM
02 Tacoma temp gauge fluctuating and trans stopped working Poncho0206 95.5-2004 Tacomas & 96-2002 4Runners 3 07-10-2015 07:21 PM
Changed transmissions now reverse lights wont work madxman21 86-95 Trucks & 4Runners 2 07-09-2015 11:26 AM
Tags
2002, clicking, coming, front, grinding, hub, loud, make, noise, real, reverse, reversing, squeaking, tacoma, turned, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
