Clunk while backing up
So the last couple weeks i have really started noticing a clunk from the front suspension on the passenger side while backing up. It is not only a audible clunk, but you can feel it. Almost like something is moving in the suspension. Nothing while i am going foward, just while backing up. I don't think it is CV shaft related because it doesn't really matter whether i am backing straight up or turing. Only does it once and then it doesn't do it again. Any input would be apprieciated.
get under there and check for torque on your driveshaft fasteners and u-joint play. sounds like something's got too much slack which is only being taken up in reverse. does it happen just once when you go forward after reversing?
I have done the CV check where you crank it hard in either direction in 4wd and listen for clicks and pops. I have none of that. All that happens is the driveline starts binding up and the tires shimmy.
Poncho0206
07-10-2015 06:21 PM
Kluch8651
07-09-2015 10:39 AM
