Cleaning oil galleys on 3.0 rebuild
Hello all,
Just wondering how to remove the what appears to be a steel ball used in the build process of both the block and heads on the 3.0's oil galleys. Im rebuilding the engine on my 450,000 mile extra cab and got stuck here.
Thanks Tweasl
Thanks Tweasl
I'll first hit it with the tig torch and when it cools and contracts,hopefully it will fall out. If not then I'll weld a rod on there make a small slide hammer and beat it out. After, I'll tap for NPT and plug. Lots of other heads and blocks use the NPT plugs and this should be no different except the steel ball is cheaper for production.
Larry
Larry
09-04-2015 09:27 AM
