cleaning an 02 sensor?
I have heard that carb cleaner or evena torch can clean 02 sensors.. Can anyone tell me a safe way to clean one and get all the gunk and sut off it?
thank you
thank you
Thats also what I heard. but them someone told me that the actaully sensor tip is so small and hidden that it wouldnt work.. I guess the debate is still out.. anyone??
thanks for the input guys.. It seems the 02 sensors are the originals and the truck has 235k on it.. I just bought it last year as a project and now I need it to pass emissions...
I went ahead and got the new ones at lunch break today.. Lets hope the sluggish idle and terrible gas mileage get better...
did you check the wiring like I suggested on your other thread?
like I said, code 21 and 27 are heater related for the front and rear sensors, respectively... since you got both codes, I'd check for voltage at the heater connectors to make sure those are working, and you can also check the resistance of the heaters on the sensors.
montanatruck
02-26-2017 07:07 AM
