chugging at 1500-2000 RPMS???
Old 09-17-2007, 01:34 PM
mcerwing's Avatar
hello.
i just bought my first toyota last thursday (91 pickup v6 3.0 3vze), and the tps was bad on it so i replaced it.
now if my truck is in 1st gear or neutral and i rev it up to only around 1500 rpms, the rps drop drastically and then come back up and drop down again. it's kinda like a chugging motion.
but it only does this if i try to keep it at the 1500-2000 rpm range. when i'm normally driving and on the gas, it does just fine.
also, it doesn't do this when my tps is disconnected.
could it be that the brand new tps is bad?
Old 09-17-2007, 01:44 PM
Blurr's Avatar
did you adjust the TPS after installing?
Old 09-17-2007, 01:50 PM
mcerwing's Avatar
umm...
no.
how do you do that?
i'm use to my old POS 89 ford ranger where you plug the tps in and go.
is it hard to adjust?
Old 09-17-2007, 02:12 PM
mcerwing's Avatar
ok...
i searched and found it.
thanks
how to adjust tps
Old 09-17-2007, 03:13 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Check your timing when your done....if you have a timing light.
Davebarbier
11-03-2015 03:28 PM
Flightguy
10-02-2015 05:34 PM
Jdgarrison
10-01-2015 05:22 PM
Jdgarrison
10-01-2015 02:11 PM
shredder4286
10-01-2015 01:09 PM
Quick Reply: chugging at 1500-2000 RPMS???
