chirping noise--wheel bearing? tie rod end?
I own a 1991 4Runner 3.0 a/t. I've noticed for a while now that the front left area of the vehicle has been producing an odd chirping noise every time I hit a bump or travel on a rough road. It seems like it's coming from the front driver's side wheel well.
Any thoughts?
Any thoughts?
Maybe a bad or missing sway bar bushing, lower control arm bushing, plastic inner fender loose or missing a screw, bent metal dust cover on shock.
Try bouncing on the left front fender and see if you can reproduce the noise and then track it down.
I haven't had time or daylight to check it out thoroughly yet, but the problem is really getting worse..
I have a hunch that it's the control arm bushings..the sway bar bushings look fine.
I can't really produce the noise with putting my weight on it.
09-04-2015 09:27 AM
ripp96
07-25-2015 02:32 PM
