Checking Vacuum Leaks - should i Use Carb Cleaner of WD40 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-22-2008, 09:26 AM   #1 (permalink)
simpsons721's Avatar
Send a message via AIM to simpsons721
Red face Checking Vacuum Leaks - should i Use Carb Cleaner of WD40
Im going to check some of my vaccum hoses for leaks
should i use wd40 or carb cleaner
all i know about checking for leaks is spray on the hoses and listen to the idle
is the noise a noticeable noise that you cant miss
also what does the liquids actually do by bean on a cracked hose
__________________
94 4runner 2wd 2nd gen 3.0 V6 3VZE Auto
Started this Forum AT 131,000 NOW AT 149,500 Miles
I need all the help i can get i want to match the guy in the forum with the pic of 333,333 milege
simpsons721 is offline
Old 12-22-2008, 09:34 AM   #2 (permalink)
wardriver's Avatar
Do you have a propane torch? You can run an unlit propane torch with the valve cracked open over the suspected hoses while your engine idles. If you pass it over a hose and it idles up and take the torch away and it idles down - the replace that hose. The propane going in the system will correct the Air Fuel ratio causing it to idle up.
__________________
Current Toyota
-95' 4Runner - 3.0/AT - New HG - Yakima Rack - MT's - Hella's - GPS- Sat Radio - Onboard 120V
Former Toyotas - 81' Trekker- 70' FJ40 - 76' FJ40 -72 FJ40 - 85 Hilux (ZERO options)
Staff Mod for nHunting.com a community forum for hunting/fishing/shooting
wardriver is offline
Old 12-22-2008, 09:43 AM   #3 (permalink)
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Neither. Starting fluid is the thing to use. On the other hand, I've had vac leaks in the past and starting fluid didn't help track it down at all.
A propane torch is good because it will "smoke", so to speak. The air from the vac leak causes the gas to condense and appear as smoke. On the other hand, see above paragraph......third sentence.
The best thing, if neither of those methods work.....and you still suspect a vac leak, is find a mechanic with a vac leak detector. It purges smoke into the vacuum systems and smoke will pour out wherever the leak is. I had one at the cold start injector I couldn't find, and that found it in about 3min's......long enough for the smoke to fill the upper intake.
Oh, sometimes clamping all the hoses off.....one by one....at the source or termination of the line will do the trick. You've cut off the leak and the motor will either smooth out/speed up or slow down, depending on the behavior the suspected leak.
__________________
Matthew
Context is everything....
Quote:
Originally Posted by abecedarian View Post
freckles, shmeckles... that was your acne reflecting on my pearlescent skin.
Get smacked....join chat!
http://www.yotatech.com/misc.php?do=flashchat
thook is offline
Old 12-22-2008, 09:48 AM   #4 (permalink)
i may try the propane trick (doesn't sound safe)
right now my truck idles at 600 rpm 750 is normal
i throw the egr code
i know some of my hoses are a little cracked so im gonna eliminate that problem
also i need to check my egr with a vacuum pump
i can also try starting fluid ill figure it out any other tips
__________________
Old 12-22-2008, 09:51 AM   #5 (permalink)
atistang's Avatar
you can use a flammable brake cleaner also, carb cleaner can sometimes eat at rubber so its not the best thing to use
starting fluid is what i always use
atistang is offline
Old 12-22-2008, 09:56 AM   #6 (permalink)
thook's Avatar
Brake cleaner will erode hoses, too....
__________________
Matthew
thook is offline
Old 12-22-2008, 10:18 AM   #7 (permalink)
wardriver's Avatar
Quote:
I would wager that Carb Cleaner is more volatile than propane....
But with any of the aforementioned methods USE COMMON SENSE! (IE don't smoke or over spray on exhaust manifold or EGR valve tubes ect)
__________________
Current Toyota
Old 12-22-2008, 10:54 AM   #8 (permalink)
atistang's Avatar
the only thing about propane is it will settle in valleys, so if an amount of it settles somewhere and gets ignited then its a very big flash
atistang is offline
Old 12-22-2008, 04:02 PM   #9 (permalink)
TNRabbit's Avatar
Propane or MAPP gas works great. Used it successfully many times on multiple vehicles.
__________________
TNRabbit
Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap
3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/
Quote:
Originally Posted by Junkers88 View Post
Like the good book says "you can give a man a Toyota and he will wheel for a year, you can teach a man Toyota and he will wheel for a lifetime."
yotatech 3:16
TNRabbit is offline
Old 12-22-2008, 04:21 PM   #10 (permalink)
thook's Avatar
Maybe I wasn't holding my mouth right.....
__________________
Matthew
thook is offline
Tags
30, 4runner, air, brake, carb, carburetor, check, checking, cleaner, common, leak, leaks, red, vacuum, wd40
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
checking for vacuum/exhaust leaks techniques taikowaza 86-95 Trucks & 4Runners 4 10-13-2008 02:52 PM
Killer Vacuum Leaks youngyota88 86-95 Trucks & 4Runners 10 11-01-2007 12:58 PM
Checking for Vacuum leaks/carb clearner rdharper 86-95 Trucks & 4Runners 4 11-11-2006 09:03 PM
checking for exhaust leaks evilcow 95.5-2004 Tacomas & 96-2002 4Runners 3 10-03-2004 06:24 PM
Carb cleaner vs throttle body cleaner---same thing? Bob_98SR5 Maintenance & Repair Archives 6 09-12-2003 07:03 AM
2009 InternetBrands, Inc.
