| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
checking for vacuum/exhaust leaks techniques
__________________
92 4runner,Thorley Ceramic Headers,Stan's Custom Exhaust,OME Suspension,DowneyHDCoils,MarlinHD Clutch,PIAA520s,24/30"Magnaflow Muf/Cat,Warn Hubs,BudBuilt IFS Skid+Xmbr,Sonoran Truss,Odyssey Batt,33x10.5 BFG A/T,ISR Mod,Boyle's Alternator,TJM T-15,Demello Sliders,Warn XD9000,Dual 4.88 Truetracs,LCE bored TB,Weasy Cams,NWMP Xtnd Range Tank, and most important,Husky Liner WOT Mod :) |
#2 (permalink) | ||
You could up pinch off the hoses one by one where they enter the TB. If the idle goes up when you pinch off a certain hose, the leak is upstream of the pinch point of that hose.
The aerosol can idea goes like this; you spray an flammable evaporating aerosol (so the spray doesn't leave a mess) over the vacuum lines, if your idle jumps up a bit, the flammable spray found it's way into the intake via the leak.
__________________
1990 Toyota 4Runner 22RE 5spd *Aussie Locker*York OBA* Quote:
Quote:
More info on 4Runners |
#3 (permalink) |
use a unlit propane torch and wave it around slowly where u think a leak is. The engines vacuum will pull in the propane and make a change in the idle speed
#4 (permalink) |
wish I'd thought of that unlit propane torch idea for my truck.... if you spray the lines down, do small portions at a time, and use quick sprays. don't hose the whole thing down at once, you'll never figure out exactly where your leak might be
__________________
I blame the automatic transmission for the wussification of America 1983 Toyota Pickup. 22r, 5 spd, 4x4, totally sweet chrome steelies and 31x1050 mud kings, and now an Aussie Locker. |
#5 (permalink) |
thanks guys- I will try the unlit propane torch and listen to the idle speed for changes. I'll post back if I find anything.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Killer Vacuum Leaks | youngyota88 | 86-95 Trucks & 4Runners | 10 | 11-01-2007 12:58 PM |
| Checking for Vacuum leaks/carb clearner | rdharper | 86-95 Trucks & 4Runners | 4 | 11-11-2006 09:03 PM |
| Checking TPS.. where does the vacuum for the throttler go? | n8inks | 86-95 Trucks & 4Runners | 10 | 09-12-2006 04:51 AM |
| too lean CEL, what's a good way to check for exhaust leaks and vacuum? | firedog | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 12-11-2004 07:45 PM |
| checking for exhaust leaks | evilcow | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 10-03-2004 06:24 PM |
