| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Checking a Clutch?
#2 (permalink) |
sounds more like hydrualics than the actual clutch. Check the slave cylinder while someone pushes the clutch to see if it's working, and check for leaks. You may have to bleed it. Or the pedal could just need an adjustment.
__________________
87 4runner 4x4 SR5 22RE ARB Bull Bar, 31X10.50 Mastercraft M/T's, Stock 4.10 Gears, Flowmaster Muffler, LCE Header AISIN Manual Hubs, Marlin Crawler Sliders 190XXX miles |
#3 (permalink) |
To check the clutch, best to do this in a open parking lot. Don't ask how I know.
Put the truck into 5th gear and step hard on the brake. Slowly let out on the clutch, you should stall the engine. Otherwise, you would look for a reving engine and no going forward when you drive. Clutches smell like REALLY HOT brakes when they are slipping. May want to concider replacing the shifter seat if you are having issues going into 1st or reverse.
__________________
Life is too short to have to work.... RIP - 4 July 2008 - '88 4Runner, Audiovox Cruise Control,Valvoline Full Synthetic Gear oil, SR5 instrument cluster, '95 4Runner Seats, Rear U-bolt Flip
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Checking for codes | Robrt32 | 86-95 Trucks & 4Runners | 5 | 06-09-2007 08:59 PM |
| Code checking | MAXIMUS1968 | 86-95 Trucks & 4Runners | 1 | 09-15-2006 05:32 PM |
| Checking valves... | MLesch | Maintenance & Repair Archives | 1 | 06-24-2004 07:57 AM |
| Newbie checking in.......... | Amkeer | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 04-30-2004 05:28 AM |
