check engine light help no code id
Old 01-24-2008, 11:42 AM
stevec8720's Avatar
ok i have a 1995 p/u 22 re and i tryed clearing the cel. disconnected the battery for 10 minutes both terminals. the second i start its back on. the code for it is 2 blinks pause then seven blinks i checked a few times same thing. what does that mean. theres no code for that in my book. help please! anything helpful would be appreciated. thanks
Old 01-24-2008, 11:52 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Try this link:http://www.off-road.com/toyota/tech/codes/index.html
There aren't any codes that aren't covered somewhere.
Old 01-24-2008, 11:58 AM
Elvota's Avatar
You have a code 27.
Old 01-24-2008, 12:00 PM
stevec8720's Avatar
yea whats the code mean tho i dont see what it means anywhere. what kind of malfunction is it
Old 01-24-2008, 12:03 PM
applesauceman5's Avatar
I hope you have a California vehicle. A code 27 is the sub oxygen sensor which is only on CA vehicles. It's the oxygen sensor behind the cat.
Old 01-24-2008, 12:04 PM
MSR
MSR's Avatar
sounds like your after cat o2 heater went bad. Disconnect the sensor and check resistance across the two similar color wires usually white or black little or no resistance good, open bad
stevec8720's Avatar
SUB-OXYGEN SENSOR CIRCUIT OR SUB-OXYGEN SENSOR HEATER CIRCUIT
--SUB OXYGEN SENSOR/HEATER/CIRCUIT
--ECU
so o2 sensor then. change the one before or after the cat?
Old 01-24-2008, 12:05 PM
MSR
MSR's Avatar
after
stevec8720's Avatar
opps thanks for the help
Old 01-24-2008, 01:20 PM
stevec8720's Avatar
thanks for the fast replies. now is it possible to put some sort of resistor in the connector like how the egr mod is done just curious. this way i dont see that stupid light while im waithing on the sensor.
Old 01-24-2008, 01:30 PM
stevec8720's Avatar
anyone
Old 01-24-2008, 03:55 PM
thook's Avatar
Nope. But, you could always put a piece of tape or groovy sticker over it.
sonic concepts
07-01-2015 02:33 PM
rbravo1
06-29-2015 01:34 PM
Alex Bessinger
06-28-2015 10:05 AM
94hiluxZE
06-22-2015 10:42 AM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: check engine light help no code id
