check engine light CODES ???
Old 03-11-2008, 04:47 AM
Shock5's Avatar
Can I pull codes and read them without a scanner? If so how is it performed?
Thanks
Old 03-11-2008, 04:52 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Run a search on pulling codes. It can be done.
Old 03-11-2008, 05:56 AM
js9924's Avatar
depends what year some you can jump the diagnostic port at e1 and te1 then get in the cab and watch the CEL flash (this is obd1 equipped vehicles 2nd gen) count the times it flashes and that is your code. You can search for the codes there are plenty of threads on it. good luck.
sonic concepts
07-01-2015 02:33 PM
rbravo1
06-29-2015 01:34 PM
Alex Bessinger
06-28-2015 10:05 AM
94hiluxZE
06-22-2015 10:42 AM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: check engine light CODES ???
