Check engine light after head gasket repl.
Hello all, new to this forum but have an 87FE non-turbo that I just changed the head gasket on. The check engine light was not on before the need for the new gasket, but now it is on. The engine runs pretty well now, except that it is a little rough around idle and the light, it smooths out with acceleration and at speeds greater than idle. I have checked the timing, it has recent new injectors, and I have replaced all the vacuum hoses with fresh rubber to no avail. Any Ideas?
The following users liked this post:
Paula Moore (10-16-2021)
Staff
A paper clip will work or small wire. Jump TE1 and E1 and count the number of flashes and look up the codes. You will need the codes for 85-87. 88 and up use different numbers.
85-87 Codes
Code 1 System Normal
Code 2 Airflow meter signal
Code 3 Ignition Signal
Code 4 Water Thermo Sensor
Code 5 Oxygen Sensor Signal
Code 6 RPM Signal
Code 7 Throttle Positon Sensor Signal
Code 8 Intake Air Thermos Sensor Signal
Code 10 Starter Signal
Code 11 Switch Sigal
Code 12 Knock Control Sensor
Code 13 Knock Control CPU
Code 14 Turbocharger Pressure
85-87 Codes
Code 6 RPM Signal
