Cheap way to lift rear end!
My truck keeps hitting the back tires and its messing them up. Every time I put something in the bed it hits worse on hard bumps.
What is a cheap way to lift the rear.
Do NOT say blocks because that would not be a solution.
I was thinking either shackles, add-a-leaf, or maybe new springs.
Thanks, Trevor
Thanks, Trevor
Measure your shackles and cross check against this page to see if any of them will fit.
http://www.trail-gear.com/shackles.html
Cheapest is to add additional leafs from the scrap yard. Will have to get a center pin I always use a bolt and round the head to fit into the axle perches.
Search for the spring deminsions and take a tape measure with you to the scrap yard, they don't have to be toy springs and you may find some lift springs.
Thanks for the help!
Well i would definitely have to say go all out and get the 63" chevies like i did for my 2WD. They are sick and the ride is sooo much better with them. Also the Axle is still over the leaf springs.
Before the Chevies
After WITH the Chevies
Before the Chevies
tc hit the nail on the head.
Bumpstops are your real problem if you are bottoming out.
That's a cheap fix.
If you're going to do something to the suspension just get a new set of leafs - you will not spend $1k on a set of leafs, I promise.
Fink
That's a cheap fix.
Fink
I don't have bump stops anymore. I took them off when I temporarily lowered my truck... I have 27" swampers on my truck and now they rub the wheel well in the back. Because its too low. I just need to lift it back to where it was when I first got it...because i removed some coils.
