cheap mods for 89 22re more HP
does any one know or wish to share any info on how squzze any extra horespower out of my 89 toy pickup shortbed deluxe with the 22re
i already got the k&n filter element and brand new fuel injector
any other mods that aint exstensive
on my 22re 164k on the motor i had a had a highflow cat 2.25'' pipe to a flowmaster delta 40 it had more power ...it was fine then i got a Lce header and man it made a difference
what will work the best is a search. https://www.yotatech.com/search.php
Try this write up: http://www.4x4wire.com/forums/showfl...&o=365&fpart=1
I really like the Aircraft sound. I remember the day I finaly got the stupid loud exhaust leak fixed on my 92 pickup with the 22re, man I miss that tuck. I heard the fan for the first time and thaught it was awsome. Mmaybe I just associate that sound with a good running truck.
yep an aircraft, but even better than adding power was the 6dB drop in noise @ 30mph, 3krpm - if anyone is intrested, i took a bunch of data points for noise before and after the fan mod, also did a full dynamatt install. but really, the fan sucks maybe 5-7 hp at 3000rpm- it was a noticable difference...
also - synthetic fluids was a good addition.
then just install the Mercury Villager/Nissan Quest fan, when that sucker kicks into the hi-speed....its plenty loud. Just knowing that the fan is not driven off the crank is worth at least 11ty billion HP gain...haha.
my dad has a mild stage 2 rv cam, a 2.25in exhaust high flow cat and flowmaster, has the k&n air filter kit and larger injectors and the truck was tuned. So other then them u can bore it, and build up the block for compression, ( stroker ) and dome pistons. altho not many people put that much into a 22re most do a swap. but my dad is running 35x14.50 boggers with 4.88 and runs 70mph at 3 grand on the high way, he has plenty of power for his truck, not no zippy imma race this honda here power but it has enough for waht it is.
I initially did a Downey Cam, 4-to-1 Headers, K&N filter, and MSD and got a descent bump in performance. I cracked a valve (running too lean) and decided to spring for the LC Engineering EFI Head/Cam, plus the Tri-Y headers and high-flow injectors and the powerband was SO much better. Smoother torque curve and obviously more overall power! Needless to say the head alone was $1K - so not exactly a cheap upgrade - but aside from a complete stroked LC Racing Motor - it was one of the most peppy naturally aspirated 22RE's I had personally seen. Too bad the block is warped and it's been sitting parked for almost a decade! Time for a V6/V8 motor swap
Nudging the MAF's spring a few ticks looser will richen you up somewhat with the tradeoff of less MPG. Advancing the timing a hair can help. Both free mods - but just beware of issues if you take either too far...
montanatruck
02-26-2017 07:07 AM
icentropy
07-11-2015 07:21 AM
