Charge/brake light...then death
I was cruisin on some steep back roads when my brake light and charge light started flickering. I figured I would just get it home and check it out. On the way I noticed that the lights only came on when the gas pedal was pushed. The lights were off while I was coasting.
I had a similar problem previously with the lights but the other way around, with the lights coming on only while coasting and going off when the gas pedal was down and charging the battery. That was the alternator but this is different.
As soon as I got home and turned the engine off, everything electrical died.
Whats the deal? The battery is not old. Was I just running off my alternator the whole way home?
Thanks yall
Thanks yall
$9.00 bucks will fix that issue , replace the brushes real easy to do I have had two with the same issue and soon as I swapped them brushes out no more problem.
Check here
http://www.4x4wire.com/toyota/mainte...nator_brushes/
It's really not as hard as it makes it out to be in the wright up mine took about 30-45 mins start to finish and the parts store parts required no soldering just drop in and go , the hardest part is remove and install the alternator but still a one man job and only less then an hour to do.
Check here
I took my battery in and its fine. I'll take the alternator in tomorrow, which sucks cause its only a year old. Lifetime warranteeeeee!!!
It was not my alternator. Autozone test said it was ok. I'v tried to charge the battery, the battery seems charged but the engine won't draw any power from it.
I figure it might have to be the wiring somewhere...but where? Where would be a good place to start if there is nothing obvious?
check the wires at the connector to the alternator , I had one do this and those wires were bad ,actually one wire was only attached by 1 or 2 strands.
Yoter
15
03-15-2009 04:44 AM
bulldog-yota
12
06-24-2004 08:15 AM
Robinhood150
21
02-21-2004 06:00 AM
