Changes form 88' to 89'
I know in 1989 toyota trucks had a design change. But I think the design change came halfway through the year, so I have been told. Is there a way to tell by the VIN # if i have the newer style or not. I am trying to order a molded vinyl floor covering, and it is a different part number form 88' to 89'. I want to be sure I get the right one.
By the way, any suggestions on where to get one? I have only found one place so far.
http://www.auto-interior.com/toyota8.htm
Does your truck look like this:
or this
the bottom is 89, the top is 88.
there was a change in body style between the years.
other than that, the frames pretty much changed the same.
or this
the frame changed slightly, but not the frame itself, the way the front bumper mounts (cross piece) I believe changed and the rear leaves I believe are a little wider.
Yes, they are interchangeable. Direct bolt-in swap.
Lot's of folks are doing that these days.
Personally, I think it looks stupid on the older body styles.
But do watcha like...
spiewaker
12-16-2015 01:10 PM
