Changed Timing Belt now Idle is low(400RPMS) - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-06-2006, 11:44 PM   #1 (permalink)
Sludge's Avatar
Send a message via AIM to Sludge
OK I set out this weekend to replace the idler pulley that goes over the water outlet. Since I had to rip out everything to replace the pully. I also replaced the T-Belt, Tensioner pully, cam shaft seals, water pump, oil pump, and the 3 drive belts. While taking the timing cover off I noticed that the driver side cam sprocket was on backwards :pat: . Done by the previous owner when they changed out the belt. I had the truck for 6yrs with no issues, so when I replaced the cam seal I put the sprocket back on the correct way. Lined up all the marks on the cam and crank shaft, installed new T-Belt and did the 2 revolutions and when the crank marks lined up the cam marks was off about a half a tooth or less to the left of the marks on the cover. Same results after several attempts, thinking everything was fine I put the truck back together.
When I started the truck back up it turned right over with no issues, but after a few mins running the idle dropped to about 400 rpms. I not sure if the belt is off one tooth or not or the truck was tuned different be cause the cam sprocket was backwards. Would the belt being off just make the engine run rough? or lower the rpms? or both. At 4000rpms the engine was running nice and sounded good. Also I haven't road tested the truck yet as it was getting late and I was tired took me about 15hours over the weekend to completed this task as I wasn't in a rush. I plan on adjusting the Idle screw and cleaning out the TB along with checking the timing also. If anyone has any suggestions or answers about the t-belt and rpms please let me know.
__________________
92 4Runner SR5
Aisin hubs,pin stripe removed,police scanner,brush guard,Monroe Senseatrak shocks and steering stablizer,Brembo rotors,Downey HD coils,Blue reverse indiglo guages. . .
http://community.webshots.com/user/sludg3
Sludge is offline
Old 08-07-2006, 06:42 AM   #2 (permalink)
rebult junk's Avatar
i just did a reinspect of my timing belt that i put on 4 months ago i thought i had a cam off or something like that so i took it apart and all marks line up on the money still trying to find out my ruff idel and some times it pops back through the intake with low idel when it is hot out side the hoter it gets the lower the idel afert all that i toke the dis cap off and found some craking inside the cap my point is ck the eazer stuf first i would have saved my self 2hr by cking the eazer stuf first
rebult junk is offline
Old 08-07-2006, 07:40 AM   #3 (permalink)
SupraSport's Avatar
This is the 3.0l ???
__________________
My Projects
An unhealthy 7MGTE and 22RE obbsession
Projects:
1988 Supra NA->Turbo
1989 4runner 22re 8" Suspension IFS 22RE
1989 RX-7 getting a LS1 T56 swap =)
1989 17' Rinker bowrider Inboard mercruiser
SupraSport is offline
Old 08-07-2006, 08:15 AM   #4 (permalink)
snap-on's Avatar
Send a message via AIM to snap-on
I know your timming will affect your idle a little.
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers
92 4runner, auto, V6, OME suspension, Downey headers
snap-on is offline
Old 08-07-2006, 09:11 AM   #5 (permalink)
Sludge's Avatar
Quote:
Yeah is a 3.0 4WD auto
__________________
92 4Runner SR5
Sludge is offline
Old 08-07-2006, 09:26 AM   #6 (permalink)
Sludge's Avatar
Quote:
Less then 2 years ago I did a tune up on the rig by replacing plugs,wire,cap,rotor. Im going to adjust the Idle screw to see if this will help and pick up a timing gun to check out what my timing is at. As for the air intake tubes I will double check them again for cracks when I clean out the TB. Then check the TPS. UGH that is alot of tedious litte work to do. Not sure why the idle would be off 400rpms just by changing the belt unless I did something wrong on the belt install. O well I will bbl with some results and checking in to anymore suggestions.
__________________
92 4Runner SR5
Sludge is offline
Old 08-07-2006, 07:22 PM   #7 (permalink)
Sludge's Avatar
Welp I ripped everything back apart this afternoon and redid the timing belt just to make sure I wasnt off on the belt. Reinstalled everything again and fired up the truck. It turned right over with no issues and the idle was perfect. So I must have been off a tooth or two. So when doing the timing belt on the 3.0 make sure all the marks line up. I thought I did but I was wrong.
__________________
92 4Runner SR5
Sludge is offline
Old 08-08-2006, 04:44 AM   #8 (permalink)
TNRabbit's Avatar
Sorry to hear you had to tear it all back apart (it's a PITA, I know) but I'm glad you found the problem--Happy Motoring!
__________________
TNRabbit
Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap
3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/
Quote:
Originally Posted by Junkers88 View Post
Like the good book says "you can give a man a Toyota and he will wheel for a year, you can teach a man Toyota and he will wheel for a lifetime."
yotatech 3:16
TNRabbit is offline
Old 03-22-2007, 04:37 PM   #9 (permalink)
I too have the 3.0 and recently replaced the timing belt. I thought all was good and aligned. At cold startup no problems. Then I run it for a bit and I sometimes eventually get a low idle with timing off. Sounds pretty obvious, but the kicker is the sometimes part. Because sometimes when its good and warmed up she idles just fine. Was yours similar to this?
89 v6 is offline
Old 03-22-2007, 05:05 PM   #10 (permalink)
Brenjen's Avatar
You might also have gotten a vacuum leak, especially if you forgot to plug the lines back to the power steering pump.
__________________
'95 4Runner 3.0 Automatic bone stock; it's becoming a project slowly but surely, one part at a time
"If ye love wealth better than liberty, the tranquility of servitude than the animated contest of freedom, go from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains sit lightly upon you, and may posterity forget that you were our countrymen!”
Brenjen is offline
Old 03-22-2007, 06:06 PM   #11 (permalink)
Quote:
What are those for?
I could've put them back in reverse.
I'll check.
89 v6 is offline
Old 03-22-2007, 06:08 PM   #12 (permalink)
Brenjen's Avatar
They're for idling up the engine when putting the power steering pump under a load. It doesn't matter which side you put where, just so long as you have them hooked up or plugged off.
__________________
Brenjen is offline
Old 03-22-2007, 06:16 PM   #13 (permalink)
TNRabbit's Avatar
You mentioned the cam sprocket was on backward; you know one goes ridge to the front and the other goes ridge to the back or prevent the belt from slipping off, right??!?
__________________
TNRabbit
yotatech 3:16
TNRabbit is offline
Old 03-22-2007, 10:10 PM   #14 (permalink)
toyota_mdt_tech's Avatar
Well, first off, that cam gear wasnt on backwards. They are opposite of each other to keep the belt from walking too far one way or the other. Usually, the drivers side will have the flange outward, pass side, it will be inward. As for your other symptoms, it sounds like late ignition timing. And if you didnt move the dist, it has to be a belt off one tooth.
__________________
Toyota Master Diagnostic Technician
"MDT"
1998 Toyota Tacoma TRD V6 4WD 5 SPD
1998 Chevrolet K1500
1999 Toyota Camry
2003 Toyota Highlander 4WD
2007 KTM 85SX 17/14
2006 KTM 300XC-W
2005 KTM 65SX
2004 Kawasaki KLX 110
2003 Honda XR50
2002 Yamaha TTR 125L
2002 Kawasaki KLR650
2002 Suzuki Eiger 400 4WD
2004 Cargomate<--link
GeePaw® Racing<--link
toyota_mdt_tech is offline
Tags
idel, ls1, ruff
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Anyone changed the timing belt on a Sienna before? Crazychopstick General Vehicle Related Topics (Non Year Related) 6 02-22-2007 12:24 PM
engine belt/timing belt replacement question gomezza Maintenance & Repair Archives 2 04-11-2005 03:48 PM
anyone who has changed a 3.4L timing belt Jared Ajlouny Maintenance & Repair Archives 14 11-28-2004 10:04 PM
Does low idle=more power & high idle=less? Yoter 95.5-2004 Tacomas & 96-2002 4Runners 1 08-13-2004 06:11 PM
How do I know if my timing belt has been changed? tango 95.5-2004 Tacomas & 96-2002 4Runners 4 03-27-2004 01:03 PM
2009 InternetBrands, Inc.
