cel codes
cel codes
I have a 89 p/up 22re. The cel light shows codes 51 and 71. Switch sensor and egr system. Codes found here. www.troublecodes.net/Toyota/ How important are these the fix right away? Are they a PITA to replace? What is the switch sensor? Does that mean I have to replace the egr valve? Yotatech has helped me with many things before. Thanks folks!
"pete f passed away quietly in his sleep on July 13, 2008
look at pg. EG1-113 it will explain what I said.
I cleared the codes and drove about 50 miles. No new code. The engine ran fine before the light came on. It still runs good. I'll run some seafoam through it and some throttle body cleaner. Thanks.
71- two things can cause that. the engine reaches operating temp and the ECU tries to open the EGR valve but the temp sensor on the EGR valve isn't up to the right temp, or the engine reaches operating temp and the ECU tries to open the EGR valve but the temp sensor on the EGR valve isn't up to the right temp. the first one could be a faulty temp sensor on the EGR valve and the second one could be a restricted EGR passage.
51 is a "switch signal" meaning, IIRC, the TPS is not signalling IDL to the ECU, the clutch switch was on or the a/c was on.... but I could be wrong.
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
