CEL code 25 Need Help please.
I just bought this 94 yoda prerunner with the 3.0(I know) 5spd 4x4 yata yata
anywho it has been burning oil and smoking on startup here and there but just recently the check engine light would come on and it runs a bit off in the lower rpms and wont smooth out till about 2500. I did the self diagnose and it came up with a code 25...
I just changed the plugs and they had a little oil on them(obvious) and they also looked rich. I was reading up on what the code 25
AIR/FUEL RATIO LEAN INDICATOR--LEAN SIGNAL SENT TO ECU FROM O2 SENSOR
--INJECTOR FAULT(S)
--FUEL PRESSURE
--OXYGEN SENSOR
--AIRFLOW METER OR MAP SENSOR
--IGNITION
--ECU
so the only thing I can think of is that maybe this oil I am burning is making my o2 senor hate life and that is why it is rich..?
I am sure you guys have many good thoughts on this thanks
--INJECTOR FAULT(S)
--FUEL PRESSURE
--OXYGEN SENSOR
--IGNITION
--ECU
Check up on my thread...lots of good info there if your truck is doing the same thing mine is:
https://www.yotatech.com/forums/f116...k-gear-150667/
code 25 is air-fuel ratio lean (not rich)
possible causes:
engine ground bolt loose
E1 circuit open
injector circuit / injector
fuel pressure low
VAF meter malfunction
PAIR system malfunction
Heated O2 sensor heater circuit malfunction
O2 sensor malfunction
Ignition system (timing, etc.)
ECM (ECU) malfunction
possible causes:
E1 circuit open
fuel pressure low
possible causes:
E1 circuit open
fuel pressure low
possible causes:
E1 circuit open
fuel pressure low
you can try unplugging the maf and see if it still runs or runs better. when they go bad they can cause the vehicle to run way too lean or too rich. make sure the intake tube isn't broken after the maf
possible causes:
E1 circuit open
fuel pressure low
possible causes:
E1 circuit open
fuel pressure low
1 Post
if the o2 is telling the ecu im lean the ecu will over inrich the motor to make the o2 happy but if the o2 is stuck on lean then its just going to get richer and richer get my drift
if you wanna check out the o2 get a multimeter its going to be your friend start your rig get it wormed up unplug the o2 with motor running and test it make sure you do it to spec like they tel you in the fsm if she goes low in volts to high in volts you know the o2 is fine if it stays low or high then you know the o2 dumbed out on ya
hope it helps in my rig i have a air/fuel gauge on the piller so i can gheck on the fly and i know if thers something wrong
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
