Cd install kit
Cd install kit
Which kit do I need for a 92 model truck? It appears several models say they will fit. .but the one I bought isn't right and I can't seem to find the correct one
Are you talking about a kit to install a CD player? If so, most CD players come with tapped holes on the side so you can use the brackets that came with your factory stereo. If you do not have those, you can probably find them at a junk yard or on eBay for cheap. Just make sure the CD player is not too long or it will not fit.
I did not think of that. If I remember correctly, the connector is the same for any Toyota '87 to I think 2011. I believe they changed the harness in '87, so an '86 is different. Do you have a picture of the truck harness or the harness you bought?
Chris Cook
03-01-2016 10:39 AM
ZRTALPHA1
02-21-2016 12:12 PM
